atm to cellular?
ml
hi
i need to soon work with some atm machines that have buit in modems
minibank 1500
not sure if i can get to the serial port or if the modems are
integrated nor am i sure even if i get to the serial port driving
that modem if the commands out would be 'industry standard'
but wondering if anyone might have any such experience or a link with
info on above?
basically i need to replace the pots/fxs phone lines with a cellular
modem
i am aware of one or two but they cost around 600 to 800 and was
looking for some alternatives
if i found a cheep iden or cdma analog fxs adapter that might be a
solution, or if i could get to the minibanks serial port i could use a
much cheeper iden or cellular modem
any tips appreciated thanks
Ryan Weihl
ml said:
hi
minibank 1500
with info on above?
modem
a solution, or if i could get to the minibanks serial port i could
use a much cheeper iden or cellular modem
Hi, the motorola i700 can be used that way with a serial cable.
I used it with a laptop to get on the internet from remote locations.
that was with motorola MIKE models.
rw
ml
hi
minibank 1500
with info on above?
modem
rw
--[/QUOTE]
appreciate the post, but not sure if i can get to the serial ports
in the machines i assume not
I am aware if i can get serial, the iden units can do CSD /out via
serial out of the phone to another serial device
i guess don't have serial out of the device i have pots i am likely
to be stuck to interface with
so was hoping to find some low cost serial/iden to pots adapter
JosephKK
rw
so was hoping to find some low cost serial/iden to pots adapter[/QUOTE]
PCCA Std. 101 covers the AT command set for CDPD and GPRS wireless
modems. Except for the wireless extension it is the same as normal.
