ATX Computer Power Supply Wiring Question
Searcher7
I am putting an ATX computer power supply into an arcade video game
cabinet, and I want to make sure that all of the cabinet's harness'
power/ground pins are used. The harness has four pins designated for
+12V, but the power supply's main 20-pin output connector has only one
+12V pin.
So I intend to use the two +12V pins from the square 4-pin output, and
one more +12V pin from one of the 4-pin peripheral power connectors.
Do I need to use the grounds on these same connectors also?
I already have enough(eight) grounds on the main 20-pin connector(if I
include the 3.3V sense), but I wanted to be sure.
Any advice would be appreciated.
Thanks a lot.
Darren Harris
Staten Island, New York.
Baron
+12V pin.
Thanks a lot.
Darren Harris
All the grounds are common as are the +12 volts. Its your choice ! But
I would use all the wires if possible. That way you get less volts
drop.
Michael Black
+12V pin.
None of those +12v lines are separate. They all come from the same
point in the power supply, and the multiple lines are there either for
better current capacity (it's sometimes easier to have a number of smaller
wires in parallel than one big bulky wire that is too stiff to do much
with), or to bring power to different places (as in the case of the power
connectors for the drives.
It really depends on the current you demand from the power supply. The
more current the game uses, the more there will be a need for multiple
wires so the voltage drop across them is not problematic.
The ground wires are the same thing, if what you are using can't handle
the current needs of the game, then there will be voltage drop.
But in the case of the ground lines, the issue isn't just the +12v lines,
but the +5v lines too, since the ground lines are common to both supplies.
Michael
Searcher7
drop.
Best Regards:
Baron.- Hide quoted text -
- Show quoted text -
Thanks Micheal and Baron.
The Game's harness has two power connectors. One with four +12V pins
and four Grounds. The other with two +3.3V, four +5V, and four Grounds.
(Then of course there is the Hot, Neutral, and ground input
connector).
I'll make sure all of these power pins and grounds are being used.
(With all the output leads/connectors the power supply has this of
course will not be a problem).
Since this is an ATX power supply I will have to connect one "power
on" pin to one of the grounds.
I assume that the +3.3V sense can be treated like any of the other
grounds. And the only two pins I won't bother with are the "Power
Good" and +5V Standby", whatever that is.
Thanks a lot.
Darren Harris
Sparkfish1
+12V pin.
Thanks a lot.
Darren Harris
As most have said all the ground ( black) wires are common and go back
to one point
To minimise the voltage drop and ensure the current carrying capacity
it is best to use all the ground wires
I have made some bench power supplies from salvaged Computer PSU and
found this source informative, instructive and useful
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
I found searching other "conversion" articles a useful way of
understanding the wiring
I hope this helps
