ATX power supply fan noisy.
I
Ian Jackson
Michael A. said:
Ian said:
My PSU fan seized solid, very solid (nice and quiet, though). The
replacement seemed rather noisy for my tastes. I eventually got the
original fan freed off. [It needed the application of a hot soldering
iron to the end of the spindle.] It ran for 18 months after being well
re-oiled with WD40. It was still going fine when, some time ago, I doing
a spot of once-in-a-while spring cleaning inside the case. So I re-oiled
it again with some '3-in-1' oil. It's still running fine.
WD40 isn't a lubricant. It was developed for 'Water Displacement',
or in plain english, to spray on ignition wires that got wet.
Regardless of what it was developed for, WD40 does leave an oily layer.
It penetrates well, and prevents/halts rust. It also serves as a
sort-term lubricant. Despite what the purists might say, it does work
well as a switch cleaner/lubricant.
Which '3-in-1' oil. That is a brand, not a type.
It's the type in a small metal tin with a plastic nozzle - the very same
tin I've had on a shelf at the back of the garage for about 40 years. I
haven't a clue what the official grade is, other than its the general
purpose domestic stuff, like you'd use for oiling door hinges and
bicycle chains. And latterly, of course, computer fans.
mm
Any 2-wire, 80mm, 12VDC, 0.30A (approx) will do. Got a Radio Shack nearby?
http://www.radioshack.com/product/index.jsp?productId=2102826 will do.
Probably cheaper at some place like Frys.
Radio shack has a great webpage in many ways, but one enormous flaw is
that if you click on a link, it might say the part is out of stock,
even when stores have it.
I signed up to get an eamil when their remote A-B switch was back in
stock, and after months I got it, and figured well maybe it's also at
a store now too. So I went in and they had two and the clerk said
they had never been out of them.
He was very confident, and I had gone in the same day I got the email.
It seems unlikely they had in stock items actually shipped for the
same reason they sent me the email. They probably did have them all
along.
So to with the item above. It says it's out of stock, but when I
click on Find it in STores, it gives 10 stores around here that it
seems to say has it. I'd call some stores and see.
P&M
I
Ian Jackson
Which dries into a nasty, insulating film over time. I use PTFE to
lube small motors. It Works a lot better than WD40 ever could, and lasts
a lot longer.
'3-in-1' does make an electric motor oil.
Don't get me wrong. I'm not 'recommending' WD40 or 3-in-1 bicycle oil
for lubricating computer fans. It's just that I needed something, and
those were what I had immediately at hand. The sky did not fall, and
continues not to do so.
I
Ian Jackson
Michael A. said:
Ian said:
Michael A. said:
Ian Jackson wrote:
In message <[email protected]>, Michael A.
doing
oiled
a lot longer.
<http://www.radioshack.com/product/index.jsp?productId=2102643>
I have had to clean up a lot of messes caused by people who used both
of those. I know gun collectors who have spent a lot of time removing
the hardened film of WD 40 off of the gun parts they are restoring.
They won't even allow a can of it around their homes or shops.
It's a funny old world. The things that some people swear BY are often
exactly the same things that others swear AT!
U
UCLAN
Michael said:
I use lithium grease, but another brand that I can pick up from a car
parts dealer just down the street. I also use PB Blaster and Breakfree.
I like the "3-in-1" spray on lithium grease because I can reach hard to
get to places with the spray tube, yet it dries with the consistency of
regular lithium grease.
U
UCLAN
As with all websites (Petco, Best Buy, Home Depot, etc.) information
given for a product (availability, price, etc.) is for the website
ONLY! There is no way a website can pretend to keep up with the stock
details of thousands of retail stores. And only in a minority of cases
does a retail store match the price of a website. Only a fool would
think that a website saying "out-of-stock" would necessarily mean that
a retail store in BF, Iowa, was also out of stock.
I just bought a nice vinyl screen door (I'm 200' from the ocean) from
Home Depot that wasn't even available on their website. Apples and
oranges.
mm
The first paragraph is a digression. OTOH, you've digressed by
bringing up other websites as if one could deduce what RS is like by
knowing a little about what they are like. It's true that
many websites act almost like the stores don't exist. For example,
the discussion of warrantee on one was not accurate wrt to purchases
made at a store. And Home Depot and Lowes have terrible pages in
general. Once I looked at kitchen faucets at a nearby Lowes, where
they had 8 models that I could have used. When I wanted to review
them later that day, the website showed none at that location, and it
was hard to find out about any other location. Lowes used to ask what
zipcode the user lived in and then pick a store near there and call it
his home store. If they didn't have what he wanted in that store, the
computer user had to come up with another zipcode and see if the store
there had it. They've improved slightly. Now it looks iirc at my
"home store" and then the two stores nearest my home store. But I
have a car. Just tell me the closest store that has it and if I'll go
there now if it's important enough, or maybe I'll be nearby soon. --
I apologize. I have digressed.
I gather you have posted without knowing much about the radio shack
website. One of the reasons I called it a great webpage is that it
does indeed "pretend to keep up with the stock ....of its retail
stores." And not only that, afaict, it actually does keep up with
them. I made a mistake when I needed the A-B switch of not checking
the stores, so I'll never know what it said then, but in other
situations, when I wanted something that day (unlike this switch which
I knew I wouldn't use for weeks) I have looked for individual store
information and what I found appeared to be correct when I got to the
store.
Of course I won't know what happens between the time I check the
computer and the time I get to the store (although I could call and
ask them to reserve it for me) and of course there is shoplifing etc.
so actual stock doesn't always match inventory records, but with
computers it's not hard at all to keep track of inventory for each
store. They probably did it anyhow and then just made it available to
customers.
Their own website? It's you who recommended a radio shack part. Do
you think that RS doesn't charge the same price at the store as
online?** And what does this have to do with the OP, who likely
wouldn't quibble about a dollar or two when he hasn't been able to
find what he wants anywhere else so far? **Plus they have free
shipping to any participating store, which I'm sure is almost all of
them. Since they have stores in almost every US state, they charge
sales tax on internet orders too, I presume. If the store has it,
it's just as good as online and it's quicker.
Only a fool would
So now you're going to call names. All this misinformation and
irrelevancy about RS just to call me a fool!
Anyhow, he'd think that if he figured the stores never stocked it at
all, and would only have it if he had it shipped to the store.
Because like you say, stores don't stock all the same things the
warehouse does.
oranges.
You don't know much about Radio Shack.
U
UCLAN
??? Whose first paragraph? Not mine. The word "all" includes even
Radio Shack.
stores."
Not at all true. I suggest you read the "ITEM AVAILABILITY" section
of its website:
"...Some items are either temporarily out-of-stock online (and may be
available at your local RadioShack retail store)..."
online?
Gee, they even say they might not. From their online site:
"...Prices advertised on this site are for online orders only."
Well, I didn't call you a fool. I wrote that "only a fool would think..."
If that description fits you, fine. If the shoe fits, as they say. As far
as my "misinformation" goes, are you claiming that the information given
at the site is incorrect?
Apparently, much more than do you. I also know how to read fine print at
a website, including Radio Shack's.
Mike Tomlinson
David Farber said:
I would like to replace this two-wire, 80mm square, power supply fan. The
power supply is used in an AudioReQuest music server and is powered on
continuously. The part number is, NMB-MAT 7 followed by a model number of,
3110GL-B4W-B54. 12V DC, 0.30A.
Funnily enough, I've just replaced one of those today.
I've found a few places online that have them
listed but when I call they, don't have them in stock or the price is
prohibitively expensive. Is there some generic fan that will replace this
and not cost more than the power supply itself?
Yeah, you can use a generic replacement but if it's powered 24/7 it
won't last long. Find a good quality ball-bearing replacement from the
likes of NMB-Mat, Panasonic or Papst. You'll be glad you did.
