Audio channels input problem
Ouroboros5
Aug 20, 2010
hello, i build the lm386 audio amp circuit to drive the input if an mp3 to a small speaker but when it comes to audio tracks that use both audio channels one is very weak. I have a 1/8 stereo phone jack where both outputs go to one side of a 10k pot and the other pin is grounded. In the 10k pot the middle lead goes to pin 3 in the lm386 and the other is grounded. Ive tried to connect the negative pin in the phone jack to the grounded lead of the pot but it gives me the same result. as for the speaker the positive is connected to pin 5 and the negative to ground. is there something wrong with setup? Do i have to supply one pot for each channel? Or is there something wrong with my ground?
Is it a dual pot (i.e. with 6 connections -- 2 complete potentiometers) or just a single pot (3 terminals).
If the latter, then you're converting the signal to mono by combining both of them. That may be fine if you only have a mono amplifier though.
it would help greatly if you provided a circuit diagram
14,486
ok
well here is one commercial way mixing a stereo input to a mono output is done
as a variation you could omit the 2 trimpots on the input and have a single pot on the line after where the 2 channels combine
cheers
