audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Ante,
This inverter will heat with about 100W so it will try to draw 600W. That is 50A from a 12V battery.
As I said before, then the output transistors will try to conduct 25A each! But their max rating is only 15A. Do you think they will blow open or they will short?
If the load is only 250W then the output transistors might survive, until the load is turned off. It is too bad there are no protection diodes.
Do you think the output transistors would be destroyed immediately by the inductive voltage spike?
Then without a fuse there will be fireworks! Dangerous??
MODERATOR EDIT:
MODERATOR EDIT:
