author of the transformer article
Kevin Weddle
Feb 23, 2004
1,620
http://www.electronics-lab.com/articles/transformers/index.html
I found your article very interesting and very in depth. I am not interested, at this point, in mass production. My question is about the electrical characteristic. My calculations involve inductive reactance rather than number of turns. What is going to be the drawback in my shortcuts to building the stepup autotransformer? Is there any wrapping that goes between the core and the winding?
Kevin Weddle
Feb 23, 2004
1,620
I was able to construct the autotransformer with a couple of drawbacks. It turns out that I had to solder the magnet wire together and tapping it is difficult when it is already wound. I was aso too lazy to make the wire large enough to handle the current. We will see if this is the case.
MP1
Dec 7, 2003
3,399
Kevin, when I mentioned that you might want to send a personal message to the author of the article, I was referring to the "instant message" feature. Click on his name in one of his posts and you will be able to send him a personal message from this site.
MP
Kevin Weddle
Feb 23, 2004
1,620
It turns out that my autotransformer did not have enough reactance to keep the power outlet from blowing the fuse. I did, however, keep the windings intact. The inductor that it turned out to be is a good power inductor with a less than perfect equation. If anybody is curious I will explain a little further how I did it.
