Auto-On timer switch
Chris
Hi All,
I am looking for a "auto-on" timer switch for bathroom fan
I wann to have the fan running constantly and only shutoff
when override, but it will turn back on after eg, 5 , or 10 minutes
there is not preset off time, I wanna to be able to turn it off at any time
and it will turn back on automatically.most timer nowaday are auto-off.
any suggestion is appreciated
thank you
W
wmbjk
Hi All,
thank you
One simple solution would be to use a "delay on make" timer. You'd be
able to turn the fan off and immediately back on, but it wouldn't
start again until the delay time expires. There are hundreds of
models, the most common and inexpensive are probably the fixed-time
types used in HVAC applications. About $10. This should get you
started
http://search.ebay.com/delay-on-make_W0QQfrppZ50QQfsopZ1QQmaxrecordsreturnedZ300
Wayne
samuel c
Chris said:
Hi All,
thank you
simple , use a Pneumatic time lag sw ,wire the fan live to com and fan
to nc contacts , these are normally used for out side lights and stair
wells etc... but for the inverse function . please bare in mind that
these may not be suitable for mounting in a bath room and may have to be
located out of the room as per local reg's .
when I googled " Pneumatic time lag switch " google came up with the
first page of uk listings so these may be a uk only part ?
all of this may or may not be of help depending were you live .
just wandering , why do you need to operate the fan like that ?
Samuel c .
Bill Kaszeta / Photovoltaic Resources
Hi All,
thank you
See
http://www.intermatic.com/Default.asp?action=subcat&sid=96&cid=53&did=5
you need SPDT such as FD32H
Use the normally closed contacts that oped during the timing.
Bill Kaszeta
Photovoltaic Resources Int'l
Tempe Arizona USA
[email protected]
Chris
thank you all for the suggestions
they are helpful !
clare at snyder.on.ca
they are helpful !
Hve the auto off timer operate a relay - Normally closed
