autoanswer telephone line
merco
hi
how is it possibile to wait for some rings and then activate the line
to capture DTMF signals ?
thank you
O
OBones
merco said:
hi
thank you
Yes.
merco
well, i see...
but i asked "how" ?
OBones ha scritto:
O
OBones
merco said:
well, i see...
but i asked "how" ?
I know, hence why I canceled the message, I missed the "how" part.
Detecting rings is done with a RC network across the line, like on this
schematic with R7/C3 (bottom right)
http://obones.com/2Lignes1Tel/Schema.png
On this one, you get an optocoupler in the path to interface with low
level voltage (12V) logic.
To activate the line, I think it's enough to put a resistor across it
but can't remember the exact value. And detecting DTMF tones can be done
with an MT8870 like on this schematic:
http://obones.com/2Lignes1Tel/ToneCommand2#/Schema.png
Hope this helps.
merco
thanks, the problem i have is how to pick up the line...
maybe a 600 ohm resistor ?
John Fields
Yes, that will work.
The second problem is that you're top posting. Please bottom post.
Joe G \(Home\)
You need several circuits.
a. Ring detect circuit
b. Something to count the rings before answer
c. something to loop line and draw loop current from line/telephone exchange
d. something to couple the audio after looping
e. something to decode the dtmf
f. something to hangup.
JG
N
Nico Coesel
merco said:
hi
thank you
By using a ring detector, a DTMF receiver and a microcontroller.
Rich Grise
hi
thank you
Hack an ordinary answering machine?
Good Luck!
Rich
jasen
hi
thank you
a ring detector, monostable, counter, relay, line transfromer,
DTMF decoder...
or use a modem. many V90 modems will decode DTMF if you ask them nicely.
Bye.
Jasen
