Autohelm 5000 Boat going in circles
Glenn Strazds
Autohelm 5000 Boat going in circles; Hunter 40
Hi there I thought I should ask this group; members with an Autohelm 5000
that have experienced their boat going in circles while endevoring to make
the autopilot work and what they did to get it to do what it i ssuposed to
do....
Is the controller defective? a nor and gate needs replacement? The fluxgate
compass is close to a magnetic article?
Followed the owners manual for setting it up ?
Pondering replacement - Navman system to go with the 3100 series instruments
already purchased and sent back for warranty - which do work well otherwise
including nema
Thanks Glenn Strazds
Ed
is the fluxgate compass working with the autopilot off?
Is the rudder indicator working with the autopilot off?
Did you double check your wiring?
Can you steer the boat with the AH5000 with the pilot off but using the
steering mode? Can you steer with the steering wheel?
The answers to these questions will narrow it down. The pilot has
manual modes that by using them you can diagnose a problem.
BTW... are you in AUTOPILOT mode or NAV mode when this happens?
Glenn Strazds
Hi there Ed..
How would I tell this? The green light cycles and the dial rotates to a
course..
Rudder indicator? = The dial that rotates - literally when turned on to hard
over..
I have not followed the wiring through the bulkheads yet.
Looking at pictures of other peoples Autohelm 5000; I've seen a small board
with power regulators on them... I have not seen this board in my setup
unless it's inside the drive unit..
steering mode? Can you steer with the steering wheel? Yes
The answers to these questions will narrow it down. The pilot has manual
Tried by the manual Here now
Autopilot mode with various gain level settings
Bruce in Alaska
do....
including nema
Did it ever work for you, correctly? If not, then first thing I would
check is to see, if the controller to actuator wiring is hooked up
backwards. Ie controller says turn right and actuater is turning left.
This happens alot more often than one would think, with consumer
installations.
Bruce in Alaska
Lynn Coffelt
installations.
Bruce in Alaska
Aw, heck, Bruce beat me to it! If this is a new installation, and has
never worked just right, there is a 50/50 chance that the motor wiring needs
to be reversed OR the rudder position transducer/sender mechanical linkage
is turning it's shaft the wrong direction (does the linkage form the letter
"Z" or the letter "H"...... or is the sender mounted right side up or is it
inverted?)
All common problems, even when trying to do the install "by the book".
Lots of us have been there, done that, more times than we'd ever admit.
Old Chief Lynn
Bruce in Alaska
inverted?)
Old Chief Lynn
Tis a Trueism of modern, and not so modern, Marine Electronics.....
Bruce in alaska
K
Kees Verruijt
Bruce in alaska
And all other types of electronics, hardware, software, ....
Tapio Sokura
installations.
This reminds me of a problem with an st2000+ tiller pilot we were just
installing in an Etap 26. The boat is equipped with EVS (Etap Vertical
Steering), so the "tiller" is mounted vertically, see
http://www.wslc.co.jp/yacht/img/etap/EVS_34s.jpg . When sitting on the
small middle bench at the back, you steer like you would steer with a
wheel, turning the tiller to starboard if you want the boat to turn to
starboard.
When a tiller pilot is attached to an EVS system, the pilot of course
steers backwards. If you reverse the direction of mounting in the tiller
with a certain button combination, you get the correct movement, but the
autopilot's internal compass now reads 180 degrees off. Is there a way
to fix this? I didn't find anything useful in the manual about this
situation. Could the fix be a reversing of some actuator wiring inside
the pilot, similar to what is described above? Or could it work if we
entered a declination of 180 + the real declination in the autopilot..?
An additional external fluxgate compass would probably fix this, but it
naturally costs money.
Tapio
Glenn Strazds
Hi there Bruce...
Did it ever work correctly for me; No! I'm the second owner of the boat
Hunter 40 85 model.
I did open up the controller box - tested the transistors; all OK; checked
out the pn# of the IC's several nor and gates where I will have to
completely dismantle the board to test - and build a logic table test bed as
well...
Is it possible the previous owners electronics installer guy made a reverse
wiring booboo - Does not look like it though?? Why; When the unit is turned
on it is not supposed to spin all the way around to hard over and stop?
I kinda wondered how it knew the boat is going forward - Did the hold a
course for 20 seconds; then engage; where on one occasion over a minute
decide to slowly veer towards a buoy... others - hard over
Boats far away to far to check right now
I'm close to pushing the button on the purchase of a Navman autopilot off of
ebay new
Since the drive motor is apparently compatible with the autopilot where I do
not currently need to also buy a hydraulic pump and ram;
Apparently the drive motor is permanent magnet with replaceable bearings
Ought to be OK with a new setup; Includes rudder position sensor arm
backwards. Ie controller says turn right and actuator is turning left.
installations.
Bruce in Alaska
Bruce in Alaska
Glenn Strazds said:
Hi there Bruce...
Hunter 40 85 model.
well...
ebay new
Like I stated, if it never worked correctly from the "Get Go", then
the most common problem would be a reversed drive power. Seen it
to many time to ignore. Try reversing it and see what happens, you
can't be any worse off by doing this test.
Bruce in alaska
Glenn Strazds
OK will try it
Might be giving up a new modern Autopilot humm...
1747
I have an Autohelm 500 on my CSY 33 . It works fine.
Couple of questions. You do have a manual and understand how to use
this, yes?
Second, is it possible that there is interference with its internal
compass?
(I could not figure out why the PO mounted the controller so far away
from the nav station. When I read the manual I understood why).
Glenn Strazds
Hi there..
Where is the rudder transducer located?
I would be pleased to take a couple resistance measurements
No schematics
thanks Glenn Strazds
Glenn Strazds
Hi there Tim...
Thanks for the tip... Corrosion? - test it out...
Glenn Strazds
