automatic voltage regulator
i am currently doing project on Generator voltage control system.
Could you send me circuit diagram for automatic voltage regulator that
will give output voltage of 220V/50hz AC.
Rich Webb
Sure!
.---------------. Motor
Command .---. | | .---.
------|Sum|------| Voltage |-----o----| M |-
+ '-o-' | | | '---'
'-------------|Filter|---------'
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
gearhead
You have a lot to learn, and not just about electronics. Like how to
communicate.
Care to give it another try?
We're here to help.
Robert Monsen
Sure!
+ '-o-' | | | '---'
Not bad... ;)
How about this:
| | output
Input o---------o MAGIC o-----------o
Regards,
Bob Monsen
MooseFET
Not bad... ;)
How about this:
                  |                              |       output
(created by AACircuit v1.28.6 beta 04/19/05www.tech-chat.de)
He may need the isolated version:
| | | | output
| SOME | | MORE |
Input o---------o MAGIC | | MAGIC o-----------o
o---------o | | o-----------o
If you take the knob off a variac, you can fit it with a pulley. A
small gear motor can then turn the variac up and down. A meter-relay
and a power relay can then control the power to the motor.
W
whit3rd
Generator? You're using a DC generator instead of an
alternator? If it isn't a permanent magnet type, you'd
just trim the output voltage by modulating the field coil current.
To make it AC, there's lots of designs out there: look into
into "variable frequency controls" that drive AC motors,
for examples, or "power inverter" like provide AC in
automobiles if your needs are low-power.
