Bill Bowden
- Jan 1, 1970
- 0
I have an old clock (30 day windup) I want to power with a weight
that automatically raises a couple inches every 4 hours so I don't
have to wind it. The clock will run with a 8 ounce weight hung on an
arm extending about 6 inches from the drive wheel. The main drive
wheel moves about 180 degrees per day and there are 13 clicks on the
drive ratchet per revolution, so each click represents about 4 hours
and about 3 inches of distance at a radius of 6 inches. So, the
winding mechinism has to pull down 3 inches on the arm at 180 degrees
from the weight every four hours, or some combination of radius and
distance.
My idea is to construct a solonoid with a strong magnet inside that
pulls down on the arm, moves it about 3 inches and lifts the weight up
on the other side, but I'm not sure how to construct the solonoid. It
needs to be fast acting (1/2 second or less) so the clock doesn't lose
a second while power is removed. Seems like the work involved is about
3 watts for 1/2 second (1.5 wattseconds). One foot-pound per second is
about 1.5 watts, so 1/2 pound and 1/2 second should be about the same,
or maybe 3 watts for 1/2 second ignoring losses. The battery will be 2
lithium cells in series, or about 7 volts regulated down to 5. The
pendulum will also be synchronized to a small air core electromagnet
controlled by a quartz crystal oscillator for good accuracy.
So, the question is, how to construct the solonoid to do the job?How
may turns of wire, etc. to make it work? I have a few of those extra
strong magnets from disk drives I was thinking of mounting in a tube
with copper wire wound on the outside, but I don't have the details
(length, turns, etc.) without experimenting. Maybe I can buy something
ready made?
-Bill
distance.
ready made?
-Bill
