Auton: The autonomous sailing boat
nabberuk
Jul 25, 2012
9
We're in the process of designing an autonomous sailing boat that will attempt to be the first to sail across the Atlantic sea autonomously.
The planning stages of the project have already begun, but we're looking for some more team members in the electronic's/programming field.
If you'd like to join or read more about the project then please free to join us at autonboat.com
Hope you guys at Electronics Point don't mind me posting this here!
Nathan
Batteries in the keel sounds good. If your batteries don't weigh enough it would be a good place to put some D sized sealed lead acid cells.
I don't like the idea of those solar cells being exposed to the elements. You're going to have to find a way to seal them. At the very least it will stop the wires corroding through.
You also need to take into account the effect of shading your panels. You're best off having one set on the starboard side and another set on the port side. That will give you the best chance of avoiding problems with partially shaded cells. (A trimaran design might also be effective in giving you more deck area for the panels.)
nabberuk
Jul 25, 2012
9
the cells will be housed in silicone encapsulation with all cables going through the deck so shouldnt have a problem with them. I plan to have the cells on both sides and the front. I wish there was some lightweight flexible solar cells as the sail would be an idea place to put them.
I have been looking at the larger 25ah of those batteries, I had a couple of questions. Are they ok on their side? I understand there not sealed lead acid, does this mean they would give off gasses? This could be pretty bad as everything be sealed.
CocaCola
Apr 7, 2012
3,635
How big is the boat going to be?
The larger it gets the more options you have, especially in batteries...
I also suggest having a small windmill on there, as it doesn't take much to generate enough electricity to subsidize basic navigation equipment shut down to a sleep mode, during the long dark or cloudy times... And if the boat is big enough even a small fossil fuel engine that can be switched on in dire need to charge the batteries...
CocaCola
Apr 7, 2012
3,635
That's a small boat for a trans ocean voyage, it's going to have to be rock solid if it encounters any bad weather or larger waves...
Or simply be able to survive being flattened and capsized over and over again. All good reasons to have a single hull design because something with multiple hulls is likely to be stable when inverted.
To some extent, smaller is better because the loads on various parts will be easier to manage.
CDRIVE
May 8, 2012
4,960
Trans-Ocean Voyage, There is no if. :D
