AV audio video red yellow white application
morphingstar
Mar 1, 2012
58
I bought a set of AV transmitter receiver. Cinch (lotus) inputs, white, red, yellow.
While testing it I discovered the yellow video input would handle audio signals.
Used this way would make it a 3-channel audio transmission. Application stereo music + 1 microphone.
Am I looking for trouble this way or am I just lucky having 3 x audio?
14,487
the yellow line is 99.9999% of the time the video input
ie. it will be on your unit as well
it will possibly work for audio but the circuitry isn't designed for that
Gryd3
Jun 25, 2014
4,098
Perhaps you are just lucky having 3 x audio... but perhaps you need more detail...
White is almost always Left-Audio, Red is almost always Right-Audio.
If a receiving unit.. (ie, a VCR) does not have a Red input, it treats the White Left-channel audio is 'Mono' which will be directed to both Left and Right speakers.
What you need to determine is if the Audio that gets transmitted via the Yellow input is directed to the Left Channel, Right Channel or Both, or if it simply remains on the Yellow output of the AV transmitter receiver.
14,487
uh huh ... personally I think its a really bad idea to stick audio into a video modulator and RF transmitter
ramussons
Jun 10, 2014
475
Technically speaking, you have a bandwidth of 3.8 / 4.43 MHz available which can be used for an analog signal ....... :rolleyes:
AnalogKid
Jun 10, 2015
3,058
An analog signal that usually is asymmetrical about ground. The yellow input might have a DC clamp trying to figure out where the back porch is.
ak
ramussons
Jun 10, 2014
475
ak
Yes. So offset a DC 0f .5 Volts and Ensure p-p < 1.0 volt. Technically possible to transport Audio, but ...
morphingstar
Mar 1, 2012
58
Ok, thanks. It seems none of you has actually done it and checked the results.
Detail answers:
Audio into yellow TX appears at yellow RX. No crossover to white / red.
<<DC clamp trying to figure out where the back porch>> No clue, it is an unbalanced input / output with signal and ground contact. (Obviously).
The receiving unit is a stage music amplifier with 1/4Jacks.
<<bad idea >> why, if it works? Facts, please. That is why I asked.
I'll try it more. No warnings received based on facts. I'll let you know in a while what experience tells me. Thanks for now.
14,487
that's video stuff that is taken care of in the video circuitry in the transmitter ( the circuitry that you are pumping audio into instead of video
JWHassler
Dec 22, 2014
86
The frequency-response of the video circuit might not go as low as you want for audio.
But if you're happy with the sound, there's no harm done.
