back to back zener diodes does what?
Status
Not open for further replies.
Davewalker5
Sep 20, 2014
125
What does these back to back zener diodes do?
Why are the reverse polarity back to back?
14,487
they will symmetrically clip a signal appearing across them to the approx. voltage of the diodes (6.8V)
so if there is an AC signal coming out of that Op-Amp, through R133. the resulting output past the diodes towards R132 will be a rough looking square wave
Davewalker5
Sep 20, 2014
125
I was thinking that also but, isn't U27 a comparator?
So U27 is not outputting an AC waveform i'm thinking
U24 is an intergator
14,487
regardless of the function of U27, the zeners are still acting as a symmetrical clipper
U 24 is also a low pass filter and you wouldn't need a LPF if the signal into U24 was plain DC
14,317
Even a comparator can output an AC signal. AC is not limited to sinusoidal signal. AC means Alternating Current and encompasses any waveform that is not DC. A square wave from a comparator is AC, too. The zener diodes limit the amplitude of the signal to approx. +-7.5V whereas the output from U27 can be much higher, depending on the power supply +V and -V.
14,487
yup, agree totally there Harald ... got tied up at work ... doing my job haha
didn't get a chance to respond with the info you did ... thanks :)
Colin Mitchell
Aug 31, 2014
1,416
The maximum voltage appearing across them will be 6.8v + 0.7v = 7.5v in either direction
Davewalker5
Sep 20, 2014
125
How can you tell from a Low Pass filter to an Intergator? they both look the same to me
Is it the Capacitor and Resistor values that make the difference?
I can't tell on schematics if it's a low pass filter or an intergator circuit
Any hints to know without knowing the input waveform is AC or DC
Davewalker5
Sep 20, 2014
125
they are the same
So they can have the same RC values? so how can you tell which is which? if you don't know what the input waveform is either AC or DC
How would a tech know by looking at a schematic
Davewalker5
Sep 20, 2014
125
I found another back to back zener diode on the op amps input pin
These diodes must clamp or clip the waveform symmetrically
14,487
an integrator is just another name for a low pass filter
14,487
no, not symmetrically
why do you think it would be symmetrical ?
Davewalker5
Sep 20, 2014
125
symmetrical clipping but only on the feedback loop?
The other circuit symmetrically clipped the output of the op amp
What is the difference between symmetrically clipping the feedback loop compared to symmetrically clipping the output?
14,487
Original question answered
thread closed
Status
