Bartop Arcade Help . Monitor issue
joe bartop arcade
Mar 21, 2016
I'm new to this but recently bought the Jamma Arcade kit with 16 A powersupply the thing whre im lost how do I connect the monitor do I need a PC power supply ATX to power the monitor inside if so what connections do I need . I dont want Two wires coming out of the arcade
Can some one help THANKS .
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
Thank you for not shouting. And thanks to @Gryd3 for his informed reply to your question.
Gryd3
Jun 25, 2014
4,098
I'M NEW TO THIS BUT RECENTLY BOUGHT THE JAMMA ARCADE KT WITH 16 A POWERSUPPLY. THE THING WHERE I'M LOST HOW DO I CONNECT THE MONITOR DO I NEED A PC POWER SUPPLY ATX TO POWER THE MONITOR INSIDE IF SO WHAT CONNECTION DO I NEED . I DON'T WANT Two WIRES COMING OUT OF THE ARCADE
CAN SOMEONE HELP THANKS .
Depends on your monitor. If you buy an arcade monitor, simply supply the required voltage from a capable power supply. (Can be the same as the supply for the arcade board)
*IF* you bought a standard PC monitor...
- If the monitor has a low voltage input, you can be creative and make a pig-tail to go from the monitor power input (usually a barrel connector) to the power supplt.
- If the monitor has a high voltage input... 100-240VAC, then you will need a second power cord. If you really don't want two cords sticking out of the cabinet, use a small extension cord, or power-bar. Mount that inside the cabinet to provide 2 or more AC outlets. Plug the monitor and PSU into this power bar and you are good to go.
It helps if you don't SHOUT your question.
Maybe the OP forget the caps-lock key? ... my boss types like that on purpose because it's easy for him to read... drives me bonkers though.
