Battery level indicator - Tri-colour?
Jason S
I want to use a tri-colour LED (or maybe just 3 different coloured LED's) to
monitor the output voltage of a circuit, to tell me if the voltage is normal
(green), too low (amber), or too high (red).
I have seen the "Bi-colour LED battery voltage indicator", but was wondering
if there is such thing as a 3-stage indicator rather than just a 2-stage.
I would like some links or schematics to assist me. I haven't had much luck
using search engines.
Thanks in advance.
K
Kevin Martin
Jason said:
Thanks in advance.
You mean like this one from Jaycar
<http://www1.jaycar.com.au/productVi...2=K&pageNumber=&priceMin=&priceMax=&SUBCATID=>
Kevin Martin
Mikegw
Jason S said:
Thanks in advance.
For three colours you only need two leds, consider what happens when both
are on.
Search for "window detectors".
How about something like this. I will set something up for a car battery.
To make up some numbers say one detector(A) turns on below 12 V. The
other(B) turns off below 10V.
Now with a bicoloured led hook A to the red led, B to the Green.
Batt V DetectA Detect B Colours
9 ON OFF RED
11 ON ON RED + GREEN= AMBER?
13 OFF ON GREEN
I know that the problem with this system is that Green now becomes the
colour for overvolt, but it gives you a start.
HTH
Mike
Jason S
are on.
9 ON OFF RED
13 OFF ON GREEN
HTH
Mike
Umm ok, that sounds like a start I suppose. I'll check it out later on.
Thanks =)
dmm
Thanks in advance.
Jaycar have an RGB led for $5.95 (ZD-0270).
You could also use a bi-colour led. Use the green and red for the normal and
high functions, then oscillate the signal to the led to create amber for the low
indicator.
Jason S
and
the low
indicator.
Thanks. I'll take that into consideration, as I've read that a 3-pin package
is not as common as the 2-pin. Easier to install on a PCB also. Now all i
need is a good battery level circuit that will control it for me! I'm
looking for a schematic as I want to be able to twink with the
components/operation. Like I want to be able to control the low, normal and
high voltages with precision, if possible. e.g. 13.6V.
