Battery Pack temperature sensor (Thermistor)
Spehro Pefhany
Hi, all:-
Is there any standard for the thermistor used in battery packs?
10K? B=????
Best regards,
Best regards,
Spehro Pefhany
Greg Neff
Thanks, Greg.
Unfortunately, that B (3435 +- 1%) is not very widely available. 8-(
Best regards,
Spehro Pefhany
That's why everyone uses the Semitec parts. You should be able to get
them here: http://www.paltronicsltd.com/linecard.php
I don't know how the spec was approved using a single-source part.
This is a perfect example of how not to specify a component within a
spec.
Greg Neff
VP Engineering
*Microsym* Computers Inc.
[email protected]
Spehro Pefhany
Thanks, we`ll do so.
spec.
That particular Japanese company is one of the most experienced in the
thermistor field (the first by a long shot to develop very cheap yet
high precision parts AFAIR), but you`d think there would be second
sources..
Best regards,
Spehro Pefhany
Ben Jackson
Why in the world would you care about your battery temp to 1%? Isn't
the point just to avoid setting them on fire with the charger?
Greg Neff
Well, yes and no. Another problem is cold temperature charging, which
can damage cells, reducing the capacity. Also a B value tolerance of
1% does not directly translate to a temperature accuracy. See:
http://www.semitec.co.jp/RT/AT/103AT1_11.xls
The Smart Battery Data Specification requires that the smart battery
be able to report temperature with an accuracy of ±3°K. So, you need
an accurate thermistor to meet this performance requirement. I don't
know the origin of the requirement.
Greg Neff
VP Engineering
[email protected]
Rich Grise
spec.
Well, what do you expect from a passel of bureaucrats? If they knew
their elbow from a hole in the ground, they wouldn't have got the job
of bureaucrat in the first place. ;-)
Cheers!
Rich
Spehro Pefhany
Cheers!
Rich
Ishizuka`s representative probably wrote that part of the spec. ;-)
Best regards,
Spehro Pefhany
Richard Henry
1% does not directly translate to a temperature accuracy. See:http://www..semitec.co.jp/RT/AT/103AT1_11.xls
During a design review I stated that my heater-control thermistor
circuit could sense the temperature on a display within 5 degrees C.
When I was asked if that was good enough, I replied "We're not making
beer".
Spehro Pefhany
beer".
What *were* you making?
Best regards,
Spehro Pefhany
Spehro Pefhany
Whoa, what incredible performance, wonder how much they run in small
quantity.
There are lots of very inexpensive 1% thermistors these days,
especially in SMT (eg. 0402). I'd be interested in how they
manufacture bead thermistors to that tolerance, considering they
change more than 4%/Kelvin.
Best regards,
Spehro Pefhany
Jim Thompson
On Thu, 06 Sep 2007 08:45:53 -0400, Spehro Pefhany
[snip]
Best regards,
Spehro Pefhany
4%/°K ? Seems high?
...Jim Thompson
Spehro Pefhany
[snip]
Best regards,
Spehro Pefhany
4%/°K ? Seems high?
...Jim Thompson
coeff ~= (B/T^2) = +3.8% for B = 3435 @ 300K (Semitec)
= +4.7% for B = 4250 @ 300K (Murata)
Best regards,
Spehro Pefhany
Spehro Pefhany
Ruggedized displays.
Ah, I see. I thought you were displaying the measured temperature (my
usual requirement) rather than measuring the temperature of the
display!
Best regards,
Spehro Pefhany
Richard Henry
display!
We could have gotten a more accurate measurement of the display
temperature if we had placed the thermistor in the center of the
display. However, the useers would not like that.
dalai lamah
Un bel giorno Spehro Pefhany digitò:
Digikey gives me nine different models (they differ in resistance tolerance
and package):
P12007CT-ND
P12008CT-ND
P12009CT-ND
P12010CT-ND
P12011CT-ND
P12012CT-ND
P12013CT-ND
P12014CT-ND
P12011DKR-ND
