BC 547 NPN Transitor Vb, Vee & Beta value?
Status
Not open for further replies.
rajat
Jun 3, 2012
16
Gents,
Sorry I have to break my previous query soft start circuit' into two otherwise it would look length. It is very simple question but I am just a hobbyist trying to understand slowly.
I am trying to replace p-mosfet with BC 547 NPN transistor.
Datasheet
http://datasheet.octopart.com/BC547-Fairchild-datasheet-7074.pdf
Can anyone advise on how can I calculate capacitor and resistor value to be used....assuming it is 12 v battery?
I tried to use this transitor calculator
http://www.csgnetwork.com/transistorcalc.html
But am not sure for what values should I put in for Vb, Vee & Beta
Any advise greatly appreciated.
Um, you cannot replace a P channel MOSFET with an NPN transistor, you would need a PNP transistor, unless you are making changes to the surrounding circuitry.
How about showing us a schematic of using the MOSFET.
Starting two threads within minutes of each other about the same thing in the same section of the forum with two totally different subject lines.
You must have been put a lot of thought into what was the most annoying thing you could do.
Carry on with your discussion here: https://www.electronicspoint.com/soft-start-circuit-t263551.html
Status
