Beckman 20 MHz 9202 Oscilloscope Repair
ericwilk
Jan 31, 2015
18
Hi there. I just acquired one of these and the unit powers on but no traces. When you try to add a lead, ground and get a sweep it pulsates the display up and down (the readout) but no trace. Tried internal calibration and audio signal. Fuse is fine obv.
The vibrations did seem to occur when I had the cycles per time set to harmonics of 60 Hz which seems suspect (60hz wasn't an option). The PSU is PT-5500M and although the chassis is grounded directly to the AC in ground (and many board points use that) there is a green lead on the transformer that registers nothing with a continuity test (green into power board, chassis, etc.)
I'm assuming a subset of components uses this lead as a ground... I'd assume the green on the PSU is ground but I don't want to guess and potentially start a fire. I could solder this to the chassis though. The 110/220 switch seems to be modified. Nothing is hooked to green, it looks like white joins with green explicitly via a rubber-sealed connection (which I did not open so who knows if that's the culprit) but regardless it still should have shown on a continuity test.
Any ideas? I'm not an oscilloscope expert. I could always play with the 1,000+ servos, instead :D
ericwilk
Jan 31, 2015
18
Brown is common orange hot. I have a crappy multimeter but it didn't blow. (AC ratings are high though. I destroyed the thing with 2 Li+ cells in parallel which is < 2A). I see no way green isn't ground. Let's try this... I just need to find the right gauge wire.
Also, will test continuity on the other wire with the same marking just in case (sanity check).
EDIT -- I'm an idiot and could have been electrocuted. Hot to ground will produce a current :V
Glad I thought of that. Tracing out the wires is tough since there are so many taped and my meter is a piece of crap. I'm guessing the wires labelled 0 are ground but I don't want to guess.
14,483
before you go any further, and destroy the unit or zap yourself ... do some serious searching for a service manual or at the very least a schematic :)
in this section of the forum and down the page a bit, there's a whole list of service manual sites ... one of them may be able to supply the manual
cheers
ericwilk
Jan 31, 2015
18
Okay, got the schematics. The outlined part is the transformer I'm talking about. The rest is the power board (looks like AC to DC converters and to TV)
http://i.imgur.com/mQOigcZ.gif
For each connection there are 2 labelled the voltage (110 or 117) and one labelled 0.
I would think the one labelled 0 would be the ground but it's going to the main switch which makes no sense.
Here are more pics for reference (may want to go bottom-to-top):
http://i.imgur.com/7XT36xA.jpg
http://i.imgur.com/tfaC25Q.jpg
http://i.imgur.com/j0KP2aa.jpg
http://i.imgur.com/QHapxbh.jpg
http://i.imgur.com/d5Ftm0t.jpg
http://i.imgur.com/4dT22lD.jpg
http://i.imgur.com/6KlGJsF.jpg
http://i.imgur.com/zNpelJP.jpg
http://i.imgur.com/haFkJsP.jpg
http://i.imgur.com/sYT6a9j.jpg
The covered leads on the PSU read "0 V"
Oh, and sorry everything is upside down but I have the unit turned over to get underneath.
Thanks in advance!
ericwilk
Jan 31, 2015
18
Actually it doesn't look like the PSU is even grounded.
I'm ruling out noise by isolation from the AC source then calling this quits for a while.
If anyone knows what else could cause this, PLEASE let me know ^^
