Morning all - newbie to the forum. Not my first forum though and I have searched through old threads before asking my Q.
I'm a complete beginner as far as SS electronics is concerned I'm afraid. When I started into DIY audio 3 years ago I decided teaching myself High Voltage valve amp building would be a great idea. Really enjoying the results, but in hindsight starting with low voltage would have been more sensible - especially as I didn't know the difference between volts and amps!
Anyway, my latest valve amp is using SS electronics to provide DC heating for the valves and it's going in a cupboard, so I am putting a small and quiet fan at the back. I've designed a control circuit with a thermistor/trimmer setting the output voltage from an LM317 - that sets the fan speed nicely if the heat increases. I also wanted to add a warning light to alternately flash a couple of red leds if the temperature on a different thermistor exceeds a set level - should be OFF when cold.
The 555 timer bit is fine, plenty of material and sample circuits around and I've played with it on a breadboard to see how stuff changes with different values and configurations. I've got this working in 2 ways and wanted opinions about them.
1) 555 pin 3 to resistor & led - but use a BC547 (because it's to hand) transistor to control the current flow. Collector to LED cathode, Emitter to 0v, Base to junction of thermistor & trimmer allowing me to set the trip point. This works ok but the led flashes faintly as the voltage approaches 0.6v. No problem, just bugs me a tiny bit. Also with this method I can't alternately flash the LEDs - I can put them in series and flash them together and that's ok.
2) As above, but remove the BC547 and connect the thermistor/trimmer junction to pin 4 (reset) of the 555 and configure it so that when cold the voltage at the junction is below 0.8v. This also works, uses less components and the switching seems to be binary. Also I can alternately flash as per original design.
Any reason not to use pin 4 this way, to hold the 555 DOWN while cold? Bearing in mind that this will be the normal state, so it's always going to be this way unless the back of the amp overheats the cupboard.
