BEGINNERS: HARVARD VS VON NEUMANN
U
UFO Joe
Excerpted from AVR Butterfly Site at: http://retrodan.tripod.com
VON NEUMANN vs. HARVARD ARCHITECTURE
If you are new to Microcontrollers one of the arguments you are going to
hear bantered about is Harvard Architecture versus the Von Neumann
Architecture.
THE VON NEUMANN ARCHITECTURE
Most computers we are familiar with use an architecture called Von Neumann.
The term arose out of Neumann's 1945 draft report on the ADVAC computer. He
was not, however the original inventor of it.
| RAM |
BottleNeck | PROGRAM |
[CPU] <==========> | - - - - |
| DATA |
A Von Neumann machine has one large monolithic RAM structure that contains
both program memory and data memory mixed together. Since both program steps
and data must be loaded from the same place, it can create a problem called
the Von Neumann Bottle-Neck.
THE HARVARD ARCHITECTURE
Most microcontrollers use a different system called Harvard architecture.
The larger program storage and the smaller data memory are separated. The
first such machine, the Harvard Mark I had it's programs hard-coded on
paper-tape and the volatile data was loaded into electric relays.
| PROGRAM | | DATA |
| ROM | <----> [CPU] <----> | RAM |
Harvard style machines allow program steps to be fetched at the same time as
data, thereby creating potentially faster through-put and less of a
bottle-neck. They also have the benefit that run away processes can't damage
the program stored in the non-volatile program area so they're more stable.
Many C programs lack proper boundary checking and a null pointer or an
over-run buffer can overwrite and crash a program that shares RAM with data.
If you are new to this architecture you need to keep this in mind. When
creating a routine that needs a few bytes of storage, I would normally
create that space within the routine itself. On a Harvard machine, those
bytes would not be in volatile RAM but part of the hard coded program memory
stored in ROM (or FlashRAM).
AVR BUTTERFLY PROGRAM SPACE (FLASH)
The AVR Butterfly (Atmega169) program space is 16K long and is divided into
two main areas. The top 1-2K and is usually loaded with a bootloader that is
protected from an overwrite and the rest is available for your programs. At
the beginning of each program space is an area for interupt vectors. The
first such vector is the Power-Up/Reset Vector and should contain an RJMP to
the first line of your program.
| POWER-UP VECTOR (NORMALLY POINTS TO YOUR PROGRAM) |
| OTHER INTERUPT VECTORS |
| YOUR PROGRAM SPACE (14-15K) |
| BOOT:INTERUPT VECTORS |
| BOOTLOADER PROGRAM SPACE (1-2K) |
AVR BUTTERFLY DATA SPACE (SRAM)
The data space on the AVRs is a little unusual. The 32 internal accumulators
are memory mapped as the first 32 bytes of data memory, followed by all the
I/O ports which are mapped into memory space followed by the 1K of actual
SRAM starting at $100.
|$00-$1F: 32 Internal Accumulator/Working-Registers |
|$20-$5F: 64 Input/Output Ports |
|$60-$FF 160 Extra I/O Ports |
|$100 |
| 1024 Bytes SRAM $100 to $4FF |
|$4FF (Normal Location for Stack) |
N
Noway2
Architecture.
While this is a statement of my personal observation, I have noticed
that it appears that the Harvard Architecture started gaining in
popularity with the widespread use of the DSP. The Harvard
architecture, and specifically the ability to access program and data
memory simultaneously is very usefull when processing Multiply and
Accumulate instructions where one item is a constant co-effecient
(constant in program memory) and the other is aquired data (stored in
data memory).
