BEL187 NPN Transistor
yousufrafi
Aug 25, 2006
19
Can anyone please give me the Datasheet of BELL 187 npn transistor.
audioguru2
Apr 6, 2004
12,026
Don't you mean a BEL187 and not a BELL 187?
Long ago when transistors were new and expensive, they made a BEL187 with high gain and a high max current of 1A. Now transistors are cheap so they are made with high gain but low current and with high current but low gain and you simply use both together.
mvs sarma
Feb 12, 2006
234
audioguru
BEL187 is a low voltage power NPN tranasister manufactured by Bharat electronics Limited (BEL) in India. you may compare it as a silicon equivalent of AC187 made earlier. it is to92 package but with small heat sink.
this device with its complimetary BEL 188(PNP) is used as a power out put of audio in portable radio and other applications.
perhaps sl100 with complimentary sk100 can be used, the space to be bargained.
sarma
audioguru2
Apr 6, 2004
12,026
Thanks, Sarma.
I don't know about transistors made in India.
I still have some germanium AC187 and AC188 Philips transistors.
hotwaterwizard2
Jan 8, 2004
2,022
Here is all I have.
BEL187 npn Transistor
http://www.bel-india.com/BELWebNew/UploadedFiles/Products/Plastic_package.pdf#search='BEL187%20npn'
http://www.datasheets.org.uk/datasheet.php?article=963356
http://www.datasheets.org.uk/specsheet.php?part=BEL187
NPN Driver/Output Transistor Plastic Package
TYPE
BEL187
yousufrafi
Aug 25, 2006
19
Thankyou very much for your answers.I am using BELL187 in a power supply,so what replacement should i use for this circuit?
ante1
Jan 24, 2004
4,138
The current limit circuit will work with almost any NPN transistor.
hotwaterwizard2
Jan 8, 2004
2,022
More Circuits here
http://www.electronicsforu.com/efylinux/circuit/feb2003/Musical%20Touch%20Bell.pdf
http://www.electronicsforu.com/efylinux/circuit/feb2003/Automatic%20Heat%20Detector.pdf
http://www.datasheetarchive.com/search.php?q=BEL187
