BenQ TFT Monitor FP2801
  • Thread starter Wolfgang Allinger
  • Start date
W
Wolfgang Allinger
sorry for my poor english, but I'm a German.
I need a service manual for a BenQ TFT Monitor FP2801.
Can't open that thing, 8 screws removed (housing and standoff), but I
can lift the back only for 1/2 mm. There are very strong plastic hooks
visible, but I can't move them.
Any Service Manual and/or hint is welcome.
My replyto: is set and works. Please don't use the fromto:
THX, gracias,
Saludos Wolfgang
F
Franc Zabkar
I can't help, but I believe that should be FP2081.
- Franc Zabkar
Dav.p.
Saludos Wolfgang
what 'Saludos ' ? Is not spanish ng..
i think there are other screws, have you left away the base?
If you are so sure of not, use a plastic strong thin thing to
sparate parts and lift it , if not you end with a slightly damaged (bumps?)
surface, the hooks are strong right, so you have to lift a bit strong.
lifted one only side and the game is done, i opened a samsung 17"
there was 3 hooks, one really near top, one 3/4 up center the other
3/4 down. Remeber the hooks will be on the front i think, so you
better insist to press to the center the rear cover. bye from Italy..
W
Wolfgang Allinger
Yes, but I'm living now in Paraguay.
(bumps?) surface, the hooks are strong right, so you have to lift a
bit strong. lifted one only side and the game is done, i opened a
samsung 17" there was 3 hooks, one really near top, one 3/4 up center
the other 3/4 down. Remeber the hooks will be on the front i think, so
you better insist to press to the center the rear cover. bye from
Italy..
I got it open 2 days ago. 4 screw from the fram, 4 screws from the
standoff removed, monitor layed down on the face on a blanket.
The hooks 3 @ each side, 4 @ top and bottom are very strong and couldn't
be bent inside. But they are no sharp edges, just rounded. So with an
8cm width 0.5mm thick palette-knife, I could make enough tension, that
the side hooks slipped out, then top and bottom and more tension, I
lifted the back.
Saludos Wolfgang
