Best Audio Clipping Ind Circuit
Paul kent
I am driving a 12W audio amp module from a PC soundcard and would like
to fit an _adjustable_ clipping indicator.
Would like to keep the circuit as simple as possible. Not a hi-fi
application. It's just because the PA speaker is in another room and I
cannot hear if distortion occurs.
What are the pro's and cons of the circuits below? Any other
suggestions?
http://electroschematics.com/5942/audio-clipping-indicator/
http://electroschematics.com/302/peak-indicator-circuit-schematic-tlc272/
The next is simple, but not adjustable, and would need to be modified
for a 12VDC supply.
(fourth diagram down)
Thnak you for any advice.
Paul Kent
K
Kevin McMurtrie
suggestions?
This isn't too bad, but it will vary in sensitivity with the battery
voltage. A low power regulator driving R2 and R4 will fix that.
There's a very long list of things wrong with that one.
for a 12VDC supply.
Same link.
Paul Kent
Since this isn't hi-fi, feed the speaker output to a 47 Ohm resistor,
then to a bridged rectifier, then to a string of cheap LEDs. The more
LEDs in series, the higher the illumination threshold. It will probably
be around 8 red, 6 green, or 4 blue/white. 12W RMS into 8 Ohms is the
typical quoted output of a bridged amplifier running on 14.4V.
Ralph Barone
I had long forgotten a circuit I did decades ago to do exactly this. I've
just written it up and added it to 4QD TEC:
http://www.4qdtec.com/Audio/SPPPI.html Speaker powered Peak Program
Indicator
Enjoy![/QUOTE]
Do you get a long enough optical pulse out of the LED to "see" the
clipping, or should you throw a small capacitor somewhere in the circuit?
