Best Ham Radio Transceivers (base station and mobile) for Long Range Communication in case of Disaster by Nature or Human.
John R Retired
Mar 13, 2022
155
As described in the Title of this thread, what would be the best Ham Radio gear for general communication if cell phones service
goes out like what happened with AT & T blackout recently? (Talking about Voice communication not Morse Code).
What are the current license theory equirements for such useage, (Technical) and is the range of the radios limited by the level of license
or the radio itself?
What is the general range of lowest power level Ham Radios gear up to more powerful gear?
danadak
Feb 19, 2021
1,104
It depends on your goals, your existing infrastructure (like are there repeaters in your area), local
constraints on antennas, what infrastructure services are you trying to enable.....way too broad a question.
What are the current license theory requirements for such usage, (Technical) and is the range of the radios limited by the level of license
Both, FCC regulates this. General limit for top license is 1.5 KW PEP. Top of page applies with exceptions
called out by band.
Again way too broad a question. Amateur's experiment with low power digital modes, very low data rates,
mili Watt range, up to 1.5 Kw. Range is dependent on band, antenna, power, ionospheric conditions (propagation),
ground (earth, dirt) conditions, frequency (line of sight) or ground wave propagation, building and terrain...........
Transceivers come in many varieties, specific band, all band, power level, hand held, battery operated,
line operated, modes, web based...........
And then there are security issues to consider......
Regards, Dana.
kellys_eye
Jun 25, 2010
6,512
There is no 'right' answer. There are more variables than it's reasonable to discuss but one major variable is propagation - It has less to do with the actual equipment being used but a lot to do with HOW it is used.
e.g I can communicate globally using 10W given the right conditions. I can also barely get out the county (not country) using 100's watts with the wrong antenna and wrong conditions.
All you really need is enough capability to reach 'the next person' and communications can therefore filter down through a chain of contacts.
John R Retired
Mar 13, 2022
155
Regards, Dana.
Goals
"Survival" and the necessity of communicaions if cell service is affected, due to increasingly hostile world situations and international conflict which has rapidly escalated in the past 3 years. Maybe things won't reach apocalyptic conditions but looking at the worst case scenario just in case. Who knows what might happen the way events are playing out and it is not looking good, being realistic.
CB Radio is obviously too limited, so HAM radio is the best backup communications mode and I have some electronics knowledge.
What security issues?
John R Retired
Mar 13, 2022
155
You must be talking about CW--Morse Code...what type of transmitter and antenna are you using?
kellys_eye
Jun 25, 2010
6,512
Nothing that you would find useful (to know) i.e. a 'vintage' Yaesu FT75 (CW/SSB, QRP set) currently but most of the rest of my stuff is all homebrew.
If you're based in the USA then all you need is to reach the next State (or two) and you could do that very easily with 100W max and a decent antenna.
The key to your requirement would be more knowledge of what's involved and, in particular, knowledge of propagation, antennas and antenna matching BEFORE you settled on specific transmitting equipment to use with them. On an 'immediate' basis any multi-mode capable 100W transceiver would give you a huge advantage over anyone else BUT there's an even simpler means of doing things.
Rather than advertising your presence to all and sundry (good and bad alike) the most practical answer would be to simply LISTEN and all you require is a decent all-band receiver.
On the EOTWAWKI basis I have acquired a number of receivers for this purpose ranging from antique valved receiver to a simple all-transistor all-band receiver and, finally, an SDR-based receiver with appropriate software.
Actually transmitting after the EOTWAWKI event is the last thing on my to-do list. Not something I'd recommend anyone to do.
oskarini
Aug 4, 2024
4
You need a HF radio so you can communicate with people in your city or outside your country. Its true you need a license but who cares if theres an armagedon BUY CAR BATTERIES so you can use it if theres no electricity.
And you should buy a handy, like a Yaesu FT50R (or Baofeng 5VR) and a CB too.
