best ic ?
burassu
Jul 1, 2011
36
which is the best ic the 74Hc283 or the Cd4008 ?? why ? pls help:confused:
Laplace
Apr 4, 2010
1,252
The answer is, "It depends." What is important in your situation? Propagation delay, supply voltage, temperature range, technology, price, availability?
burassu
Jul 1, 2011
36
Everything because the question says , Which is the best Ic from these two therefore it is taking in consideration everything.
They seem to be functionally identical.
They may differ in speed, supply voltage range, output drive capability, etc.
But it is up to you to decide if any of these are benefits, drawbacks, or inconsequential for you.
Check here and here.
edit: This message was composed without seeing the other reply (or yours) but it remains just as valid.
The faster one may have higher quiescent current, so if you rate speed above power consumption one is better, however if you rate power consumption above speed the other may be better. And this assumes that the speed or power consumption of one chip over the other actually makes a practical difference.
In addition, you haven't specified that you are interested in other versions, say 74HC, 74C, 74LVC, 74AC, each of which have different properties which may or may not be relevant to you.
Even more in addition, different manufacturers may have slightly different specs. Maybe operating temperature range, or packaging material, or available packages (Is TSOP an advantage for you over SOP or DIL?).
It would be a very rare component where one could not show any variant to be the "best" in some circumstance.
And I haven't touched on the cost or availability issues either. Or which manufacturer is "greener". Or which one is manufactured in a country with an "acceptable" political environment, or which gives it's workers the best working conditions, or... well, you get the idea.
