What do you find is the best way to desolder through-hole components from double-sided PCBs (without expensive specialized gear that is)?
I find that using a desoldering pump doesn't suck out all the solder and oftentimes it "splashes" the solder out around the hole as well (I do find that holding the desoldering pump a few mm above the PCB and not towards it helps, and also heating up the area with the soldering iron until right after you've used the pump helps too). A soldering wick works for one side, but doesn't remove solder from the other side as well.
