Best method for remote control of a PSU
H
Hammy
What is the best method for remote control of a PSU just to control
switching it on and off? I was looking at data sheets for relays DPDT
but they all seem to require a holding current in the coil. Is there a
relay that latches on for a single pulse and will stay latched until a
second pulse is delivered? No coil holding current required from the
battery operated control signal (see schematic).Or is there an
alternative solution?
This is the schematic. The transformers load is a 1.5W LM317
regulator.
http://i12.tinypic.com/5yx94q0.png
Thanks for any suggestions.
regulator.
Yes. They are called latching relays. Just about any large
electronics supplier sells these (see Newark Electronics, Digikey,
Mouser Electronics, etc.)
BRW
ehsjr
regulator.
To begin with, eliminate NTC1, NTC2 and SW2.
You don't need a DPDT relay - single pole
is fine. And yes, there are latching relays
that are pulse operated and do not require
holding current.
Ed
Rich Grise
regulator.
Use the pulse to energize the relay, but then get power to hold
the relay in from whatever it is you're powering. You'd need a little
circuitry to turn it off, say a gate where if power is on, then when
a pulse comes in, it gets inverted and interrupts the power to the
relay, turning it off.
Good Luck!
Rich
H
Hammy
Thanks all for your suggestions.
I think I may have found a suitable latching relay at Digikey (not
much selection). I've noticed that they must be derated 75% for
non-resistive loads. The largest current carrying capacity is two amps
resistive load and 0.5A non-resistive.
I have a 14VAC 4.4VA Transformer coming next week hopefully Monday; I
can take some measurements to see if 0.5A_rms is adequate for sure
with safety margin. The LM317 is for 12V @ 0.125A.
neon
Oct 21, 2006
1,325
WHY DON'T YOU GET TO THE LM317 AND SHUT IT OF WITH A TRANSISTOR. leave the power input as is. which has to much protection for a lm317 regulator. protect the lm317 from the secondary not from the primary. i ruther think that you don't have 35 v dc on the secondary in that case why the overkill in move protection and what not.
