Best Practices for Component Sourcing in DIY Electronics Projects
Kruti
Dec 18, 2024
Ever started a DIY electronics project only to realize you’ve got the wrong components—or worse, they don’t work at all? Finding the right parts is just as important as designing the circuit itself. Here are some best practices to make sourcing easier and avoid headaches:
Go for Quality Over Just Saving a Few Bucks – Cheap components might seem like a good deal, but they can fail unexpectedly. Trusted suppliers like Digi-Key, Mouser, or Element14 are safer bets.
Double-Check Specs Before Buying – It’s easy to grab a resistor or capacitor that “looks right” but has the wrong values. Always check datasheets and ratings before ordering.
Buy in Bulk for Common Parts – If you tinker a lot, getting resistors, capacitors, and connectors in bulk saves money and shipping time.
Watch Out for Counterfeits – Some marketplaces have great deals but also a risk of fake or low-quality components. Always check seller ratings and reviews if buying from sites like eBay or AliExpress.
Local vs. International Sourcing – Local stores mean faster delivery and easy returns, but international suppliers might have better variety. Balance speed vs. selection based on your project needs.
Don’t Ignore Old Electronics – Salvaging parts from broken gadgets can be a great way to get free components, but make sure they’re still functional before reusing them.
How do you source components for your projects? Do you prefer trusted suppliers or take a chance on budget-friendly options? Let’s share tips and experiences! ⬇️
Martaine2005
May 12, 2015
5,308
Personally, I do exactly as you have described.
Pretty much in the same order too.
But I’m not a designer, only a hobbyist and keep lots of broken boards for scavenging components.
Delta Prime
Jul 29, 2020
2,991
No. I just grabbed a handful of components that I never seen and threw them in a DIY project box shake it around a bit and everything falls into place it designed itself, but then I have to figure out what it’s for.
Externet
Aug 24, 2009
944
First choice, I source what I can out of salvaged boards from discarded or failed equipment, kept as boards to pick whatever is needed, not dismantled as components and sorted-binned.
Maaany times I use a hack saw to cut off portions of a PCB to extract only a functional section that connects in/out/=/- to the project.
Electronics components today are meant to be handled by robots; buying 'breakout' board modules help greatly instead of building printed circuit boards and functional circuits.
An old link I have unsure if exists now :
---> https://www.aliexpress.com/af/break...e_id=SB_20170927131023&needQuery=n&isrefine=y
Buying from mail order stores in quantity one is a triple robbery from pricing plus the abusive mailing they charge, thus highly avoided for hobby use. I prefer to buy a gadget with known guts to canibalize its parts.
ahsrabrifat
Jan 18, 2025
76
Local source seems the fastest option to me always. In case of international suppliers, I prefer branded suppliers. I had some bad experiences with the non-branded ones. Thanks for the write-up.
poormystic
Jul 23, 2023
187
I've been working on a TTL design that uses counters, logic gates, transistors and switches. (Of course that's how my machine works. Right Dave?)
I get my stuff from Jaycar if they've got it and I want it. Next are Digikey, Mouser, RS, Infineon, WES.
What I'd like to find is a source of really good prototyping circuit boards. I want 0.1" spaced holes, each hole with a properly riveted copper through tube.
Well, I can dream :)
Delta Prime
Jul 29, 2020
2,991
Well, I can dream
I use a Through Hole Press that is hand-operated & uses through hole copper plated rivets.
Good for double sided boards only, with “0.1” hole spacing to connect traces that are transitioning between the top & bottom layers of a PCB. Copper through tubes,I know them as via’s, I use the press for my mission critical RF circuit boards below 1GHz. :)
poormystic
Jul 23, 2023
187
Ohh
That sounds just right :) Can I borrow your riveter for a "while"?
Maybe I better get one for myself... whence came your wonderful riveted PCB making machine?
Delta Prime
Jul 29, 2020
2,991
Ohh
If you’re in Southern California, that could be very possible, I am rather fond of mine, and will not ship it. It has it’s own personality… so to speak.
I started off with what is known as
Din-7340 type A rivet .You can use a rubber mallet & pound them into your prototype board.
The link below, is for reference only.
