Best solution to clean touch screen replacement.
Kestas17
Jan 4, 2017
6
Hello everyone :)
I'm a newbie when it comes to fixing electronics. I need to clean a touch screen replacement for the T100TA Transformer book, but I'm not sure what solution to use. I dabbed a microfibre cloth in some warm water and tried to clean it, but suddenly I realized it was stupid thing to do.
I've read that best solution to clean electronics, such as screens was Isopropyl alchocol. Is that true? What advise can you give me?
14,487
only if you used lots of water. a moist cloth is quite OK, and a drop or 2 of detergent wouldn't hurt
Hicham
Jan 5, 2017
7
I use WD40 for cleaning "almost everything... Give it a try!
14,487
Seriously ... NO !!
bad advice .... never use it on any optical product
Hicham ... you really use an oily product to clean things with ?? seriously ???
Hicham
Jan 5, 2017
7
Seriously ... NO !!
Yes i do and it works. For example: when replacing iphone's digitizer screen, i use wd40 to clean the glue off the screen and it works like magic. I think i should have mentioned that it's not used to mirror clean things rather to remove things.
14,487
yeah so "clean" is the incorrect word huh !!
to remove the glue would have been better wording aye ;)
14,487
Yes. The interior side. It has glue and finger prints.
OK it is wise to use gloves when doing replacements like that :)
and soft/fine and lint free tissues are also important and keep fingers to the edges of the screens .... don't touch the main part of the panel ;)
My daytime job entails replacing LCD panels and touchscreens on a number of different products in the surveying and commercial GPS industry
I haven't used those pledge wipes you linked to ... if you have or do try them, I would be interested to hear what you think of them
Kestas17
Jan 4, 2017
6
Thank you for the advice. I will keep that in mind the next time I do something like this.
I did try the wipes. They were ok, they were not too wet, the right moisture. The only thing I didn't like is that it contained perfume, but after I cleaned the screen I couldn't smell anything.
14,487
here's an example of the touchscreens I replace
the new replacement
and below the damaged old one ... they are 15cm wide x 9.5 cm high
this was one I did today for a machine control product that looks like this .....
Kestas17
Jan 4, 2017
6
the new replacement
Cool!
I have a question actually.
I just tried the new touch screen, but something was interfering with. It seemed like something was touching it in one area, and therefore I couldn't type anything or login.
P.S I can see the feedback when the screen is touched (windows 8 notebook/tablet).
I placed adhesive tape around the inside the of the touch screen to leave a gap between the touch screen and the LCD.
I also cleaned the inside and the outside of any residue, glue, finger prints.
Do have any idea what this could be?
14,487
show me a photo or two of your touchscreen and where you have the tape
if it is like most touchscreens ... like my one above, then the touchscreen doesn't interact with the LCD panel ... they are separate components
