Biasing a JFET. Measured voltages are not as calculated
GhostLoveScore
Nov 27, 2016
71
I've been playing with this circuit:
It's simple tuned FET amplifier. It's not really practical circuit, it's just an example to see if I can calculate how to bias a FET.
Let's begin by writing what I think I know:
Tank circuit is short circuit for DC. Therefore, for calculating bias, drain voltage is 12V
Id=Vcc/R1=4mA
We will choose quiescent point at Id/2 - 2mA.
By using these methods http://www.diyaudio.com/forums/pass-labs/228897-jfet-matching-sorting.html
I measured for my JFET BF244A:
Idss=5.43mA which is about right looking at the datasheet.
Vgs,off=2.19V - again, about right
Now I have to calculate what Vgs I need to have 2mA drain current.
Using upper equation. When I turn it around I can calculate Vgs and I get Vgs=0.86V
That means Vg=Vs+Vgs=6+0.86=6.86V
From that I calculate that in voltage divider I have values from the schematics. But in real life it's not like that. I get right gate voltage, but source voltage is always about 2V off from my calculations. I understand that I my measurement of Idss and Vgs,off may be wrong, but I don't have another way of measuring them.
I tried having 4V at source and then doing the calculations and in practical circuit I got around 6V. If anything, it's always about 2V and I can just do the calculations like that, but I would prefer to know what is happening here.
What am I doing wrong here?
14,289
O.k.
Id=Vcc/R1=4mA
At this point you ignore Vds!
Or do you mean Idsmax?
Vgs,off=2.19V
What do you mean by Vgs,off? Is this Vth (th for threshold in MOSFETs) or Vp (p for pinch) as it is commonly called? I guess so as this name is used in the fairchild datasheet.
Apart from that, for an N-channel J-FET Vgs, off is negative, the datasheet gives a range from -0.5 V ... -8 V. Your measured value then is Vgs,off = Vp = -2.19 V (note the sign!) and therefore Vgs,bias = -0.86 V
Vs = R1*Ibias = 3 kΩ*2 mA = 6 V
Vgs, bias = Vg,bias - Vs, bias therefore Vg,bias = Vgs, bias + Vs = -0.86 V + 6 V = 5.14 V
Your gate voltage is too high, leading to a higher drain current than expected which in turn results in too high a source voltage.
Also note that the paremeters of the transistor vary e.g. with temperature.
By the way; It helps to use a consistent nomenclature and to observe the signs in your equations.
GhostLoveScore
Nov 27, 2016
71
Yes, I mean Idsmax
Sorry, it should be pinch off voltage. On different sites people write it differently. I'll use pinch off voltage from now on.
Of course, it was that simple. I read it a hundred times that gate should be negative in respect to source. And then I forget that and make gate positive in respect to source.
I got confused because the pinch off voltage is the same as Vds at which FET goes to saturation mode at Vgs=0.
