Bicycle generator
colum
Jul 25, 2013
180
I hurt my knee and need to exercise on my stationary bicycle so I want to attach a DC motor to the wheel to charge a battery
I want to add an analog Volt meter and an analog Ampere meter to observe output.
but when I quit cycling the battery turns the bicycle in the opposite direction .
I would appreciate a simple design to charge a battery with a DC motor and placement of the meters and any Diodes needed
Thanks for reading this and appreciate any help, I will have to do this exercise for the rest of my life
Jeffrey
14,487
yes, to be expected ;)
A blocking diode will stop that from happening
You just need to ensure that the diode selected is rated to handle a bit higher current than
what is likely to flow through it.
What type of battery are you charging, and at what current? Simply connecting a battery to a generator could either damage the battery or set it on fire.
Audioguru
Sep 24, 2016
3,656
A lithium battery overcharging could set fire to your entire neighbourhood or town. Insurance won't cover the damage.
WHONOES
May 20, 2017
1,242
Arghh, the end of the planet as we know it???????????????
14,487
yeah, good point, I forgot about that
Maybe use a car battery 40Ah and one (or more) of the dynamos that run on the wheel rim with a couple of bridge rectifiers.
I doubt that 15 minutes of pedalling that will do any damage.:D
(Could pass out from the hydrogen fumes if the Op was super fit.)
Or if you take too big a breath of it you could turn into a Zeppelin and float off the planet. [/Audioguru] :)
