Big Screen Help ? Panasonic AP-820 chassis
bloggybob
model PT-51HX41E / AP-820 chassis -- rear projection HD tv .. ok it has a
small issue when its cold .. when you start it up it has squiggly
transparent lines on the screen .. kind of like what you see on an
oscilliscope with an audio signal on it , if that makes sense ... but once
it warms up it is fine ... id like to fix this thing before it does any
major damage as the tv works great other than this issue ... i had an rca
big screen do the same thing and never did figure it out because the red
tube went out so i said forget it ... thanks for any insight , its much
appreciated
gnk
appreciated
Check the following parts (from repairworld database).
C7154, C7136, C1008, C1011 Front & Side of Convergence Amps
bloggybob
thank you so much ! ill just replace them all !! ty again
bob
Similar threads
Replies
1K
SXMWendell
  • Erich J. Schultheis, The Man with the 15 inch Cock
Replies
3
2K
