V
Vito
- Jan 1, 1970
- 0
Rick said:Well, Vito, not everyone's boat is just like yours. Many people have... oil in the bilges ...
While you may have only one battery and can reach it in seconds not everyone can.
Then "many people" should fix their leaks. It should never be necessary
to turn off the pumps in seconds.
Your installation does not apply to all or perhaps even most boaters.
True, and that's my point. Not ALL boats need a manual switch in series
with the automatic switch either.
If someone is aboard then that person may see the oil and do something to
reduce the quantity pumped overboard. It is that simple.
May ... might ... perhaps ... Hogwash. Nothing on my boat leaks oil
because I fix leaks. I also prudently keep rings of absorbers around any
potential leakers to catch any drip before any reach the bilge.
Quite frankly I worry more about my bilge overboard than I do your
caldera. If your caldera blew up it would not have nearly the same
impact on me as a few tablespoons of oil in the water through my bilge pump.
There'd be several years of winter, with no crops anywhere. The UK would
become like Iceland. Fortunately, it happens almost as often as bilges
fill with diesel (c:
When I pump bilges I monitor the discharge and am ready to switch
the pump off at the first indication of a sheen. I also have an oil
content monitor which will detect oil in concentrations greater than
15ppm and shut the pump off but I still watch the overboard when I am
onboard. It is just good practice, it is not paranoia.
I have a far simpler solution: I examine my bilge regularly and if there
were any oil I'd search out the leak and fix it. Then I'd manually pump
into buckets and decant/filter to remove any trace of oil. But that
never happens because I don't even allow salt water to accumulate, but
instead wash my bilges down with fresh water every few months. Of course
when one's leak prevention regimen is shoddy .... (c:
