Tim Williams
- Jan 1, 1970
- 0
Bill Sloman said:Obviously there's feedback of a sort, but not of a kind where you
could fiddle with the phase shifts.
http://home.planet.nl/~sloma000/0344_001_Baxandal.pdf
Just because the loop is closed doesn't mean the differential equations
aren't there. You can gain access easily enough by controlling gain or
bias (manipulating the voltage or current into the base supply, or varying
the feedback voltage through various methods: pot, variac, old school
rotating-axis "tickler" coil, etc.).
For instance, a high impedance bias supply could allow the base supply
voltage to vary (large resistance or CCS, with servo if required), and the
V-I characteristics would then be easily observed (impedance, step
response, squegg damper "best values", etc.).
Tim
