Bluetooth chips question
Je-Rock
I am going to build a board to hook up with my PDA(bluetooth enabled).
Some one have experience with this? I need to find some bluetooth chips
and antenna.
Any advice will be appreciated!
martin griffith
and antenna.
Yep there is a guy here called Boki, really helpful dude, and we've
help him a lot, sort of
martin
Jens Tingleff
*snort*!
Very funny :)
A less flippant replay is to suggest a module (using a bare chip is *not* for
the fainthearted). Google for somewhere to buy a module with programming
support.
Typically, you get a module with power, digital and perhaps analogue I/O,
antenna and supply connections. You then somehow put custom software on this
module (or add a microcontroller on the board and speak to the bluetooth module
using some serial protocol). Simple as that! Builing your own module is tricky.
Very.
Best Regards
Jens
V
vasile
Je-Rock said:
and antenna.
A bluethooth transciever is a RF chip running in 2.4Ghz ISM band.
Except the transciever itself you need also a PA and probably a
microstrip antenna.
It's a big project and require the availability of RF tools as spectrum
analyzer, eventually a network analizer for antenna caracterisation and
a lot of time, base knowledge and software (of couse it needs some
logic too...)
There are many producers of bluethooth transcievers, most of them are
keeping designs on secret and require a NDA signed by an user company.
If you are just an amateur will be difficult.
So, if you don't match all criteria above, better play with zigbee,
it's easier.
greetings,
Vasile
Je-Rock said:
and antenna.
Sparkfun has the answers you seek, they have everything bluetooth
related
modules
http://www.sparkfun.com/commerce/categories.php?cPath=16_115
antenna suff
http://www.sparkfun.com/commerce/categories.php?cPath=16_78
bluetooth_primer
http://www.sparkfun.com/tutorial/BlueTooth/bluetooth_primer.htm
forum to ask questions
http://www.sparkfun.com/cgi-bin/phpbb/viewforum.php?f=13&sid=391f1f40455efc81b0726529e039705b
John Woodgate
dated said:
network analizer
Please note that it's 'analyser'. The spelling you use indicates that
the network is fundamentally inserted.
N
Nico Coesel
Je-Rock said:
and antenna.
TDK sells a ready-to-go kit which implements a bluetooth serial
interface.
N
Nico Coesel
Is there some rule about the 's' and 'z'?
John Woodgate
I didn't notice that. Yes, 'analyser' is usually used in British
English, and 'analyzer' in US English. There are no rules; it's all down
to usage.
But in general, 'z' is correct, except for a few words, such as
'comprise', 'surprise' and 'advertise'. Apart from those, the 's'
spelling was invented in Britain by some newspaper editors in the 1920s
and isn't etymologically correct.
I normally use 'z', because it's used in IEC standards.
H
Homer J Simpson
It's not the s or z. It's the difference between anal and analyse.
Meindert Sprang
interface.
That would be Ezurio now. www.ezurio.com
Very nice modules, we use them quite a lot.
Meindert
V
vasile
to usage.
I used "analizer" because that is called in romanian language,
english is just a language I've learned at school, 25 years ago.
Of course it looks in english "analyser" is the most frequently used.
greetings,
Vasile
H
Homer J Simpson
A lot of FSU dictionaries have errors. Often the first English word is one
which is never used. Search for the meaning of 'Anal'.
John @ Trebutech
Je-Rock said:
and antenna.
Phillips BGB203/1 SIP Bluetooth Chip, with a surface mount 2.4Ghz Antenna?
[Both available from Digikey]
Almost all you need, take a look at the shortform datasheet. [Google]
John @ Trebutech
John @ Trebutech said:
Je-Rock said:
and antenna.
Oh warning, tiny 7x8mm HVQFN chip :)
Spehro Pefhany
Je-Rock said:
and antenna.
Gack! It's got a 32-bit ARM processor with 268k of flash and 40k of
RAM in that little package. The new 8051?
Best regards,
Spehro Pefhany
John said:
Je-Rock said:
and antenna.
do you know where the full datasheet is? can't find it anywhere, thanks
John @ Trebutech
Je-Rock said:
and antenna.
Antenna?
The shortform really should be all you need.
I'm pretty sure the units available from Digikey only have the SPP (Or
whatever their own brand of the acronym is...) profile on it.
I should probably connect up the JTAG and see what else I could do with
it....when I have time :(
