BONA VALVE(SOLENOID VALVE)
HzCoder
Mar 30, 2021
8
Hi , I need a help, I want to power Bona valve , with 24 AC adapter,as you know adapters comes with different amperes(currents),so which kind of AC adapters,should I use?? with 5 amp ,10 amp etc
14,313
You'll have to look up the exact part number and then the current requirements in the datasheet of that part.
The label you show gives no indication of power requirements.
Or use an AC transformer that can supply e.g. 5 A, connect it to the solenoid and measure the current the solenoid draws. This will give you an indication of the power required to operate the solenoid. You can then chose a matching transformer.
