Bone conduction low frequency speaker
Alain Hubrecht
Dec 9, 2017
I want to output very low frequency onto the skull bone. I think about buzzer or piezzo. It is just to output always the same frequency. I look for about 10 Hz, that is not possible for a speaker, so I will use something higher, pulsating at 10 Hz.
I guess a small circuit can produce the waveform, but what to use for the speaker? It should be the smallest possible.
Tx
Externet
Aug 24, 2009
944
Welcome.
Not simple, but... Try an assortment of miniature relays with the coil in series with their C and NC contacts. Perhaps one will be close to 10Hz, or tailoring a resistor in series, or RC components to bring it to desired frequency.
It will mechanically buzz nicely.
Audioguru
Sep 24, 2016
3,656
A piezo is a squeaker and cannot produce low frequencies with any force.
A small speaker has a high resonant frequency and also cannot produce low frequencies.
I agree that a relay might work.
AnalogKid
Jun 10, 2015
3,058
A cell phone vibrator is a small DC motor with an offset weight. Maybe you can vary the DC voltage to get the frequency you want.
ak
Audioguru
Sep 24, 2016
3,656
Can you add weight to the speaker to reduce its resonant frequency?
Sure, but its loudness will be reduced a lot (because then it must work harder) and to make it loud enough it might burn out.
Audioguru
Sep 24, 2016
3,656
A properly damped speaker starts and stops immediately. A vibrator motor starts and stops slowly due to its inertia.
