Alun
- Jan 1, 1970
- 0
What's the part number?
The answer's on the datasheet.
You don't need power resistors, two low power 100K potentiometers (variable resistors) are what you need.scuba14c said:Is there a way to change the 100k resistors to lower values? The most I have are 20k power resistors.
Look at the picture below:I am connecting the 555 timer output (+) to the back of the transistor and the (-) to the left pin. The center pin is connected to the output side of the inductor. The right pin is connected to the negative terminal of the capacitor. To start it I give it a pulse with the timer and then touch the negative side of the battery to the right pin of the transistor. This will get me to ~28V in less than a second, but it takes 10 seconds longer for it to reach the 32V maximum.
Is this the way it should be connected?
What do you mean the back of the transistor?scuba14c said:I tried it but it didn't work. Was the ground from the timer supposed to go to the back of the transistor?
It could be a transistor or a voltage regulator but I can't tell without the part number.I have a circuit layout from someone else who built a boost converter, but am unsure of one of the components he used. The diagram for the boost converter does not show it. Could you identify the device on the upperleft hand side of the board?
