bose awr1-2w sound problem,
Christopher Haynes
Dec 10, 2015
I have an audio fault on the above model ,display is ok but when switching the radio on a sudden boom is heard then silence. i suspect the power supply or output ic probably caused by an intermittent connexion on the mains socket i have now sorted . i would like to get a schematic for this model if anyone can help.i would be obliged and would compensate anyone who can help. Chris.
Anon_LG
Jun 24, 2014
453
Have you operated the system in the past successfully?
Assuming that the model has been confirmed to work in the past and you are setting the device up correctly:
I doubt that Bose would put a schematic up due to competition. To find the problem, may you open the device and provide clear pictures of all internal circuitry. Are there any other problems with the unit other than the loud emmision?
Pictures would help a lot, once these are supplied, potentially damaged components may be identified and replaced.
