poor mystic
- Apr 8, 2011
- 1,106
- Joined
- Apr 8, 2011
- Messages
- 1,106
Hi Guys
I bought my Bose Lifestyle 5 a few months ago and didn't get much of a chance to use it for a while. It was in somebody else's hands while they "looked after it carefully" for me, and within an hour of very moderate usage once it had been returned to me it had failed catastrophically. I suspect that the stereo has been thrashed.
So I took it to the local Bose repair place and they repaired it, absolutely not, despite charging me nearly $300. The repair docket claims that a new (2nd hand) pcb has been fitted.
When I first got it back from the repair shop, it wouldn't work at all. I was`powering it as I always had, from a 1kVA auto transformer that runs the 240V down to 115V.
I returned the unit to the repair shop and after a few days they called back saying "no fault found".
Indeed, the system was running nicely in the shop - plugged into 240V. The repair shop said the unit was designed to run on either voltage without re-jumpering and it seemed graceless to complain that I had been used to running it on 115V and it should still work on that voltage. If it ran OK on 240V I could make room for that.
I powered it up at home today and it made a loud, fluttering noise in the bass, while whiter noise, in synchrony with the fluttering, appeared in the treble.
Obviously the unit must be returned, and for the 2nd time. :-(
Can anybody advise me what is likely to be going on with this unit? I gave these repair people all my month's spending money and I'd like to have some idea whether I'll ever be able to actually use the unit.
