Bose mie2i earphone solder repair.
Stujlmbrt
Jun 16, 2013
6f6c7c93
Please help!!!
I need good simple advise from a professional on how to solder the thin two core speaker wires back into earphone speaker as excessive force had caused cable to pull out and become detached from earphone.
Please see photo!!
Any further information required please let me know.
Thanks.
RxyzM
Jul 21, 2011
Since these are BOSE headphones, I would first suggest to check with BOSE center for repairs.
If that is not possible or not an option, then, I presume you know how to solder. And, also presume that you know how to use multimeter.
Using Multimeter, please check that the spot marked under RED ink and the one next to it are showing 0 (zero) ohm resistance. Similarly, confirm that the the opposite spots also are showing 0 (zero) ohm resistance.
From the picture, it seems that the copper color wire has separated from the spot marked under RED ink/compound. So, connect copper color wire to this spot.
The silver color wire gets soldered to opposite spot to the one marked by red ink/compound.
