Boss GT-6B multiple guitar effects pedal board, 2005
N
N_Cook
Two of these known to the owner of this one have shown the same symptoms,
but never connected together in any way.
The other one apparently corrected by a factory reset (coincidence?)
At switch on the display continuously scrolls as though one of the up or
down bank select pedals
is active, ie looks like the action of someone continuously turning the
rotary encoder switch.
Have taken apart but not reassembled yet , unenclosed .
Only 0.2mm differentiating first touch to click over of the very basic click
switches under all the
foot pedals. The "wah-wah" switch is different action. Is it a stock fault
of deflecting steelwork/pivot wear/bending pcb/expanding soft inserts?
causing engagement of these switches, then just washer packings to correct
for a short time until the problem re-emerges) or something more
electronic/software or internal rotary encoder problem
N
N_Cook
Not a stuck sw problem. Unlikely rotary encoder sw problem as physically
rotating it changes the 7-segment display but the auto scrolling error
function does not. No susceptibility to touching components. Select a
funtion like tuner and the display stops scrolling and gives tuner display.
Disconnecting all ribbons except the display one , the scrolling display
still there so a main board problem seemingly. I suppose ESR caps check is
first port of call. User manual from Bossus site and schema etc on e-service
Meat Plow
symptoms, but never connected together in any way. The other one
apparently corrected by a factory reset (coincidence?) At switch on the
display continuously scrolls as though one of the up or down bank select
pedals
Have taken apart but not reassembled yet , unenclosed . Only 0.2mm
fault
correct
I never had any problems with my GT6. Used it to gig with from 06 to 08.
N
N_Cook
I asked, at receipt, whether this one had been connected to a pc and it had
not. I've just asked whether it had been connected to a sequencer and so
maybe the other one had as well, transferring corrupted code. This 6B same
as the e-service 6 pdf as far as display is concerned , buffers between uC
and display seem to be operating correctly but still scrolling with the
switch and rotary board disconnected. No obvious ESR problems, little much
else to do, check a few V if 6 and 6B agree there.
N
N_Cook
With all ribbons disconnected other than display one I noticed that the
display stabilised if "digital" fingering of the empty mainboard socket for
the ribbon that goes to the sw board and pair of analogue mx chips.
Reconnecting that ribbon the display still scrolled but tugging on the fixed
end of the ribbon stopped it. Resoldered the ends and display and overall
functioning seems normal, eg up/down bank buttons function, unlike before.
Nothing obviously wrong with solder or the crimp? terminals to the wires
that are also the solder points but something wrong there. Not PbF but
resoldered all 4 such ribbon fixed ends JIC. As maybe generic Boss problem
area they are no-name white "Harwin" 0.1 inch type connector system for
discrete wire ribbons, same crimp? system at the fixed end (inserted into
the housing then soldered to pcb) and socket end , so standard sockets at
one end and solderable thru-housing and pcb pins at the other.
So is it coincidence the other one was playing up the same way and was
genuinly cured by factory reset or same wiring problem coincidently
disappeared for the present on that one? Or of course some other
intermittant problem with this one coincident to fiddling with one
connector, the repairman's dilemma. Repairing (or not) by divination in
effect.
I've now had word back that both units have only been connected analogue to
amps and guitars, no midi or digital connections. Not bought from same
supplier either.
Meat Plow
had not. I've just asked whether it had been connected to a sequencer
and so maybe the other one had as well, transferring corrupted code.
This 6B same as the e-service 6 pdf as far as display is concerned ,
buffers between uC and display seem to be operating correctly but still
scrolling with the switch and rotary board disconnected. No obvious ESR
problems, little much else to do, check a few V if 6 and 6B agree there.
Well the 6B must have had a USB port if you are talking PC connections.
Mine had no USB. I don't recall if you could upload new patches using MIDI
as I never did.
Meat Plow
for the ribbon that goes to the sw board and pair of analogue mx chips.
fixed end of the ribbon stopped it. Resoldered the ends and display and
overall functioning seems normal, eg up/down bank buttons function,
unlike before. Nothing obviously wrong with solder or the crimp?
terminals to the wires that are also the solder points but something
wrong there. Not PbF but resoldered all 4 such ribbon fixed ends JIC. As
maybe generic Boss problem area they are no-name white "Harwin" 0.1 inch
type connector system for discrete wire ribbons, same crimp? system at
the fixed end (inserted into the housing then soldered to pcb) and
socket end , so standard sockets at one end and solderable thru-housing
and pcb pins at the other. So is it coincidence the other one was
playing up the same way and was genuinly cured by factory reset or same
wiring problem coincidently disappeared for the present on that one? Or
of course some other intermittant problem with this one coincident to
fiddling with one connector, the repairman's dilemma. Repairing (or not)
by divination in effect.
to amps and guitars, no midi or digital connections. Not bought from
same supplier either.
My 6 suffered road abuse. Was dinged and dented but never failed. Just an
FYI. Don't think those problems were endemic to the 6 unless their were
changes made to the 6B.
Gareth Magennis
click
Phone Roland Service dept, and speak to a person. If it is a common fault
they will know about it.
01792 702 701
Gareth.
Gareth Magennis
fault they will know about it.
01792 702 701
Gareth.
After making sure, of course, it isn't a power supply issue..
