Boxing day sales!
Well, I went shopping with the money Santa left me (the money my wife didn't spend on gifts ).
I saw a nice Racal receiver (it looked small in the photos). So off I went.
I ended up with a Racal RA17L
Oh, and also a Racal RA117
And also another RA117 for parts
Not to mention a pair of SSB converters
A box of assorted parts
And also a bag containing an almost complete set of spare valves. Oh, and I shouldn't forget the two power cords with the funny connectors that look like XLR sockets.
A couple of closer looks follow...
I have taken a very quick look at the 3 receivers. The first 2 look to be complete, but will need extensive recapping and possibly resistor replacement. The gutted unit is another 117 but it's missing the power transformer and the valves. There may be more missing too.
I have yet to crack open the 2 SSB units, look at the spare parts, or the spare tubes (other that a quick once-over for white getters).
It would be really interesting to get these going again. the scrap unit is pretty complete, and may be a candidate for conversion to solid state.
These will be a long term project!
It looks like the box of parts has a large quantity of unobtanium in it.
Including even more valves, shields, if transformers, coils, knobs, screws, etc...
Martaine2005
May 12, 2015
5,317
Santa and covid looked after you this year.
The 'wife' couldn't spend it all with shops closed and lockdown.
Martin
I think i got a "going to a good home" price.
Santa arrived late this year. He left me this
This scope has a massive bandwidth of... wait for it... 500kHz! But it makes up for that with a vertical sensitivity of 100μV/div.
Inside it looks like this
But the power connection is a little suspect...
The mains flex just comes in via a hole. looks like US cable with black/white & green, but has an Aussie plug.
Assuming they wired the plug something like correct, the live and neutral have been connected across the fuse, and earth has been connected to one side of the transformer primary. The plug shows burning on the earth pin. Aaaagh!
This could be fun...
Well, the good news is that the transformer was connected between neutral and ground (assuming the genius who wired this has their house wiring correct). It also explains the very well blown fuse.
Unfortunately the primary seems to be open. Also looks to be a 127V winding :-(
And the power switch is open! That may have happened when the fuse blew I guess. At least the power switch won't be hard to replace.
There's also balls of solder under the fuse holder. Oh the skills of the person who attempted to wire this up.
Woo hoo! after consulting the documentation, the transformer appears OK. And it has both 120V windings connected in series. It must have been a 240V unit. Not sure why someone butchered the power cable and stuff, but it looks like all they may have done was convince themselves the unit didn't work. (and that probably explains the price too)
Back to the SSB converters. This is the one on the left in the group photo. It is marked "OK"
PXL_20201231_122745136_compress98.jpg Top
PXL_20201231_123136337_compress3.jpg Bottom
Lots of mica caps and film caps. No paper caps at first glance. But quite a few electrolytics to replace.
Second unit. I was told this was not working, but probably just required capacitor replacements.
PXL_20201231_121851161_compress60.jpg Bottom
Immediately noticable is the lack of a dial lamp on this unit, and also there were marks under pretty much all of the electrolytics. I imagine all have leaked onto the bottom cover at some point.
Nevertheless, looks like not too much work here too.
And finally for tonight the Racal RA17L
PXL_20201231_125118905_compress42.jpg Top
PXL_20201231_125449237_compress74.jpg Rear
PXL_20201231_125810469_compress35.jpg Bottom (main cover in place)
PXL_20201231_125923106_compress29.jpg Bottom (cover removed)
PXL_20201231_130449371_compress49.jpg Some further shielding removed.
There's a lot of caps that need replacing here. fortunately the layout is really clean and I'm sure it's going to be a lot easier than some point to point chassis I've worked on.
But there's a LOT of caps...
The person who serviced the RA17L left them following notes from 19 dec 1985...
Should be a useful reference once I get it recapped.
I went searching deep in the innards of the receiver.
Look what had happened to these wax paper capacitors!
One of those stalagmites is almost a cm tall!
