John said:
You can build a fast shutter close to a source that only lets light
through for a nanosecond or less, and then measure arrival times some
distance away. Or do interferance experiments, which are exquisitely
sensitive to the speed of light. There are lots of techniques that
could detect ftl photons if they existed.
Well, you can't disprove the conjecture that something, maybe a rogue
photon, does move ftl. But no experiment has ever demonstrated such,
and there's lots of theory that says it can't happen. The burden of
proof is to show a real case. "Laws" like the conservation of energy
get much of their force from the fact that no counter-case has ever
been observed.
You can observe a quasar flash that happened 8 billion years ago, on
the other side of this universe, and look at it in wavelengths from
radio through gamma rays; everything arrives at Earth at the same
time, which is pretty impressive.
John
It is compelling to believe that there could be some way to exceed C. On one
hand, it's great to be "pushing the envelope" by researching such things, but on
the other hand, don't let simple lust blind you into believing something is real
when it is not. Any theories are just heresay until proven otherwise. This
reminds me of a post I saw here recently which went something like this... (use
a monospaced font like Courier):
Scientists Discover New Waveform:
| _______) \______ |
| Time--> |
The Sharktooth
Here's my two cents. Einstein's Time/Frame notion - and the notion that light
can travel faster than C with respect to other light - seems to be consistent
with observations made scientifically. i.e., measure the speed of light on two
opposing edges of an expanding universe from the center, and they have an
escaping velocity *delta* faster than C. But no light actually travels faster
than C in it's frame.
The other idea is that if string theory is correct, what if "FTL" is simply the
12th dimension? (I can't stand that vagueness about string theory - "if
something doesn't work right, just add another dimension...")
That said, also interesting the the propagation speed of EM radiation with
respect to C in various mediums. Research for instance, the speed of "c" in an
iron powder medium; the answer might surprise you.
-- "I think the state of the universe at the moment of conceptulization
determines part of how an entity further interacts with the rest of its reality,
and hence our experience with it." MCJ 200311
