Bridge Amplifier
Mukhalled
Aug 17, 2004
137
Hi everybody,
Please can you help me guys if this amplifier can be bridged?
This is its datasheet: http://www.datasheetcatalog.com/datasheets_pdf/T/D/A/1/TDA1521Q.shtml
SM2GXN
Feb 18, 2006
161
Hi Mukhalled!
Here's a PDF-file I had on my hdd "AUDIO AMPLIFIER ICS DESIGNER
AUDIOIC.pdf
  • AUDIOIC.pdf
Mukhalled
Aug 17, 2004
137
Hi SM2GXN,
That was exactly what i wanted. Thank you so much  ;D
Best regards
audioguru2
Apr 6, 2004
12,026
Hi Mukhalled,
The TDA1521 is able to drive a single-ended 4 ohm load so is able to drive a bridged 8 ohm load to 18W at low distortion or 26W at high distortion with a 22V supply.
Mukhalled
Aug 17, 2004
137
Hi Mr. Audioguru,
I've built the amp and it sounds pretty good  ;D. First i would use it in the car but the voltage was not enough, it needs at least 15V  :(. So i should use it for another application, maybe DVD player or something else ...
Best Regards
Mukhalled
Aug 17, 2004
137
I thought it would not work at 14,4V, but i tried in the car and it really worked  ;D. It gives 8W to 10W. It's not much for a bass box but it does well  ;D.
Best wishes
