From the datasheet it looks like the TDA2005M and TDA2005S are both the same.
They are dual amps - 10W each
There are plenty of application configurations for mono and stereo.
Hope it helps
Hi Mr. Audioguru,audioguru said:Hi Mukhalled,
Attach the schematic of your bridged TDA2005 for us to see what is wrong with it.
The only difference on the datasheets between the TDA2005M (for a bridged amp) and the TDA2005S (for a stereo amp) is that the TDA2005M is selected for a max output offset voltage of 150mV. Then it will have a max DC current in a 3.2 ohm speaker of 150mV/3.2 ohms= 47mA without a signal which also creates heat. The TDA2005S doesn't have an output offset voltage spec so it could be too high for a bridged amp.
Thanks. It is much clearer and uses many fewer bytes.Mukhalled said:Ok, I've attached it again and i hope it's clearer now...
Its minimum supply voltage is 8.0V and it uses a very high current at full output. If your supply is a little 9V battery then it won't work.the supply voltage i use is 9V.
Maybe that is your problem. This IC has a very high output current that can cause positive feedback in the wiring.Mukhalled said:I didn't use the pcb layout on the datasheet.
Good.The IC doesn't get hot when in use ...
I used
Good! You fixed it. Nice going. ;DMukhalled said:It works now
