Hi, Just un-clear why this happens! Have a 13vac Supply, after it passes through a Bridge Rectifier (4 diodes.- 13.0-approx.1.4v diode drop=11.6vdc) the voltage is 11.79VDC . Using the same Bridge rectifier but adding- Two 250uf, 50vdc capacitors in parallel to filter the DC output the 11.79vdc changes at the capacitors to 17.68vdc. My question: Why does this happen? and applying this voltage to a circuit would I use the 11.79 or 17.68vdc output for my calculations? Thanks in advance
