Bridge Rectifier Selection
FireFly3
Dec 7, 2003
35
I've been looking into selecting a one-piece square bridge rectifier for the 30V/3A power supply project. There seems to be lots of these like every other component type! Generally, they seem to have rather heavy voltage/amperage handling abilities.
What is the downside to using a bridge with significantly higher ratings than required besides slightly higher cost and larger physical size?
Would a bridge with just adequate specs put out more heat than one with much greater than required specs?
Ldanielrosa1
Nov 25, 2003
316
A higher rated bridge will more easily tolerate voltage transients and startup surges. Also it may have a slightly lower voltage drop.
