Brightest White LED
walid1
Jun 27, 2004
749
How do measure the Brightest White LED and see if it is damaged or not?
thanks
Note: I have tried to test in the same way as the normal LED, but did not give me any reading from both sides
Hero999
Oct 28, 2007
2,433
Brightness is only half the story: colour rendering index and beam angle are also important.
audioguru2
Apr 6, 2004
12,022
Many cheap "bright" LEDs are for sale but they are simply a dim one in a case that focusses the light into a very narrow but bright beam.
Good LEDs have the same brightness or more and have a wide beam angle.
Will D1
Mar 15, 2012
5
The most accurate indicators of the brightness of LED bulbs are the measured lumens or lux. Lumens measure the total amount of light output from a bulb. Lux measures how bright the light is on a surface at a specified distance.
audioguru2
Apr 6, 2004
12,022
My cheap solar garden lights are EXTREMELY bright at night if you look at them.
But they are not bright enough to light up anything nearby.
plouf1
Mar 7, 2005
26
but its interesting on how do you actually can measure a LED light, if there is any more or less easy method with more or less accurancy
walid1
Jun 27, 2004
749
In fact, no one understand my question. I do not ask about the intensity of light, my question was about how to examine it. And to know whether is good or bad? Thanks
Hero999
Oct 28, 2007
2,433
A light meter can be used to measure intensity.
A spectrum analyser can measure the power at different wavelengths.
